Question about Lands Phones
Eircom perform 100
Reset a password om eircom perform 100 handset
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Rkhiet@gmail.om
You may have forget your password
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Jan 12, 2014 | gmail.com
Right' on my phone i put a password on the messages soo no one can look at them, then the next day when i had a message i typed in a code and it said the password was incorrect, ive tried loads of...
You can perform a master reset on your handset, but in doing this you will lose all of the content that you have stored in the device. Select menu, settings,security, and then you should see eihter reset, or master reset. You will need to put the handset's lock code in and then you can select master reset. When you do this it will reset your handset's lock code to the factory default code.
Mar 20, 2011 | Cell Phones
I forgot my phone password
this happens all the time with samsungs. i went to tmobile.com/forums and found some info to fix mine when i forgot mine as well lol. the problem is it will reset your password and all your other information as well :(
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung C3510 Cell Phone
Notice for sagem 7000 eircom missing - how do you set up mailbox (answering machine0?
My Sagem Eircom 7000 handset is not charging properly when put back on the base. It usually gives a little bleep when you do this but does not at the moment. It charges for a short while but then it bleeps slowly and cut out when in conversation. Can you tell me you to FixYa!
Frankie
May 13, 2010 | Lands Phones
I have a nokia 5800 n in it wave secure is bering installed i want to delete taht but i dont know the password
you must remember your e-mail id that u used while regestering wavesecure.
proceed as directed,
goto this link and enter the name that flashes when you open wavesecure.
enter image text and click below.
NOTE
Before you do this i repeat the very important point.
do this only when you are 100% sure that your recovery e-mail id is correct and working.
if this is not the case then there is only one way left.
backup all the data and hare reset your phone.
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed
Apr 04, 2010 | Nokia 5800 XpressMusic Smartphone
We have a eircom 6010 siemens phone and it is constantly falshing base 1 and wont allow us to make or recieve a call on the handset
I have and eircom siemens phone and it is also constantly flashing base 1 and wont allow us to make or receive a call
Debbie
Jan 20, 2010 | Lands Phones
Unlock netopia 2247 router
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
May 06, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
