Question about Cameras
My Pentax SmartHead Water Pump Does Not Come On All Of A Sudden
Where can i get a manual forthe pentax water pump cam 50
Although it has a manufacturer's name of Pentax, I don't think this is a camera. Industrial Machinery may be a better option.
May 06, 2017 | Pentax Cameras
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Canon ir3570 show error 00024
check for paper jammed in fuser assy, u need to reset error code by pressing smarthead then 2and 8 SAME TIME then smarthead should go into service mode press copier then function then err ok then off on
Feb 19, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
I can't seem to get a proper seal on the valve stem (Standard American) therefore cannot fill up the tire. Should the pump arm be in a particular position?
The locking lever on the pump should stick out when you're pumping, and lie flat against the body of the pump when it's released.
If that doesn't work, try tightening the nut on the head of your pump - if it's too loose or too tight, the rubber will not seal properly against the valve stem. Also make sure the head is firmly seated against the valve (press it in firmly) before flipping the locking lever up.
It looks like you have the SmartHead on this pump. If not, make sure two parts inside the head (one plastic, one rubber) are flipped the right way. If it's set for a Presta valve and you're trying to inflate a Schrader, or vice versa, it will leak (or it simply won't fit). If you have the SmartHead, you don't need to worry about this step, it automatically adapts.
Sep 13, 2009 | Topeak Mini Master Blaster DX with...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
