Bosch f12 error code washing machine - Washing Machines
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Plus Front Load Washer; Error Code F12
Is this a model 110.47512601 HE2 Plus? If it is, I do not see an F12 error code listed. I have a tech sheet for an HE2 Plus, but I only see an F21 error code.
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. If you require further assistance in determining the source of the error, please let me know.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Posted on Jul 13, 2008
SOURCE: what is error code f27
i'm
Posted on Nov 08, 2008
SOURCE: bosch washing machine error code
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
Posted on Apr 12, 2009
SOURCE: bosch wae24363 washing machine, coming up with f17 error code please help
I had this same message last week. It is to do with the water intake (i.e. the water coming in to the back of the machine). If you have checked that the hose isn't trapped or kinked, unscrewed it and checked the filters at each end for blockages (rinse out if necessary), and you still get the F17 message, it may be because your water pressure is too low, in which case you need to contact your landlord (if you rent) or thames water if the problem is external (especially if there are any works going on near your house). Hope this helps!
Posted on Jun 12, 2009
  • 38 Answers
SOURCE: error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Posted on Jul 28, 2009
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
What does Code E:00 mean on a Bosch washing machine 7kg WAK2020SME?
It is strange, but this error code should not exist.
I found a youtube film, explaining most codes and what you can do to solve it. Take care, when you don't have the correct skills, ask a tech.
Apr 26, 2015 | Bosch Washing Machines
E36 error code
My Bosch washing machine is showing error code E36 what's the meaning?
Feb 18, 2014 | Bosch Washing Machines
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
Dec 29, 2007 | Siemens WXLP1460 Front Load
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
