Error e03 Copier misfeed,Open side Cover - Computers & Internet
    Master:
  • 663 Answers
Which copier is that? Please provide more ifnormation about the machine so that I can provide you with the correct troubleshooting steps.
David
Posted on Jul 18, 2013
E03 code toshiba photocopier
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Mar 15, 2016 | Toshiba e-Studio 207 Copier
E03 error in toshiba e studio 207
Power-ON jam:
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
TOSHIBA eSTUDEO167 misfeed E03
Check thermistors and clean if required , most likely heater section related.
Jan 16, 2013 | Toshiba Estudio 200L Copier
Red blinking light
Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
Jun 05, 2010 | Sharp AL 1631 Copier
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
Amessage '' misfeed detected'' please remove the .... from 0
before i can help you you need to tell me which brand and model is the machine.
The Message "misfeed detected" means that a paper is bee jammed inside of the copier so you should open some door and remove the paper which has been jammed inside of the copier.
Because of that i need the brand and model of the copier for i to be able to help you and tell you what to do
Jan 29, 2009 | Office Equipment & Supplies
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
E350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
May 11, 2007 | Toshiba e-Studio 350 Copier
Computers & Internet Logo
David Payne
David Payne
