Question about NEC Computers & Internet
Vertical screen lines
Vertical coloured lines of varying intensity on screen; same when external monitor connected via vga. Sometimes starts without lines, but it redevelops later
    Master:
  • 663 Answers
I suggest that you check the connection of the motherboard and your computer's screen because it has something to do with it. Or if resetting the connection won't do anything then I suggest that you let a tech check it.
David
Posted on Jul 18, 2013
Open case screws
You should open your computer and reset the data cable which connects the motherboard and the screen. If it's not going to fix it, then you would need to get a technician to look at the motherboard and the LCD so that he can identify which part is causing the problem.
David
Jul 18, 2013 | NEC Computers & Internet
My Aspire 5670 screen is dead.
Update the video drives, if that doesn't work replace the vga cable. If that doesn't work try it on another monitor.
Jan 19, 2013 | Computers & Internet
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
My laptop monitor has vertical lines all across it, so I have an external monitor, how do i connect it to the laptop
Connect the VGA cable to the VGA port of the laptop then restart the computer.
Go to display properties and enable the second screen, then disable the notebook screen to display only on the external screen.
Nov 18, 2010 | Computers & Internet
Laptop screen has very strange colours and is very dark but when conected to an external monitor the picture on monitor is OK
There is USUALLY an intensity control that you can vary the intensity. USUALLY you press aa special keyboar function button and one of the F buttons for up and another for down intensity.
Jan 10, 2010 | Computers & Internet
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Computers & Internet Logo
47 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
