Question about Kitchen Ranges
Kenmore Electric Range model 790.9260* not even a year old and oven and drovetop has stopped working, checked all house fuses, and they are fine.
5 Suggested Answers
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
  • 10 Answers
SOURCE: Oven will not come on
There is a oven controller on those type ovens and if you cannot get your oven to heat up but the stove top still works it is because there are on different circuits and the cotroller will cost near $350 if you have a convection oven and twice that for a service person to install!!
Posted on Jan 15, 2010
I have a kenmore electric range model number
There could be tripped circuit breaker or fuse to the oven. This would be the one at the breaker or fuse panel for the house. There are no fuses in the oven itself unless it is a combination oven and microwave and these would just be for the microwave.
Oct 03, 2014 | Kitchen Ranges
While in middle of baking all power lost to range. Checked all breakers and they are fine. Is there a reset botton on the range? Range is about 11 or 12 years old.
I don't have anything on that model number. Please look inside the oven or the bottom drawer for the model number.
Regards,
Richard Roth
http://appliancecafe.com
Nov 08, 2012 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Our 6 year old Kenmore Electric Range's oven just quit working. The stove top burners work fine, the light in the oven comes on and the breakers in the main house panel are all fine. It just quit heating...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Kenmore Kitchen Ranges
My Jenn-air 2 year old oven and top stop working any help? please...
Hi
If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Kenmore oven and brolier will not work
The problem lies within your oven control board. This is very common and are not very hard to replace but they are expensive. You can check the price of a new control board at sears parts.
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
My Kenmore 790.95929301 oven and broiler stopped working.
with that model im coming up with a control part number 316207620, with a seperate overlay(which is the buttons your pressing, and i would assume youll need it as well, only because the old one rarely comes off pretty!that part number is 316243317 ,(BLACK).
Dec 11, 2008 | Kenmore 95922 / 95924 / 95929 Electric...
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
