Question about Gestetner DSm622sp Digital Imaging System
How To Get The printer to work
I have inseted a extra network card into the pc closest to the printer/copier. I have connected the printer/copier via network cable to the computer. When I look on the pc i dont see the printer/copier. Could someone please help me to get the printer working. I have the drivers but am not sure how it all works.
    Problem Solver:
  • 18 Answers
Open up your printers and faxes window from the control panel. select add a printer. select a local printer option(first one)hit next and then select create a new port and select standard tcp/ip port. hit next a few times and there will be a promt for the printer ip address(find that by printing a configuration page on your printer and make sure you have auto dhcp turned on or auto on from your printer. input the ip address in there and then load the divers when they promt you. make sure you hit have disk then browse to where your driver is downloaded to and select the .dll file and you will be good to go. make sure your router is assigning auto ip address's.
Posted on Aug 29, 2007
I want to print on my epson tx550w via wi-fii
Wired or Wireless or both?( I have no idea what you are connecting, Laptop , desktop, OS, equipment, etc.) Is the printer connected via a printer cable to your desktop or does the desktop have a wireless card? Or is the printer Wireless? Three are to many open questions to list every option, take a look at this: http://compnetworking.about.com/od/hardwarenetworkgear/a/how-to-network-a-printer.htm. With more detailed info I can assist you better. Here's a Google search: http://www.google.com/webhp?source=search_app#hl=en&tbo=d&sclient=psy-ab&q=adding+a+wired+or+wireless+printer+to+a+ho
Dec 15, 2012 | Epson Stylus Multifunction Inkjet Printer/...
My printer is on 192.169.0.10 if i disconnet the usb wireless access card I can print. My printer is connected directly via ethernet cable to my pc. If i plug in the usb wireless i cannot even ping my...
I see 2 possible issues here: for one, are you sure that your printer has an IP addess of 192.169.0.10? That is not a standard format, but you may have changed it while setting up the router. Typically, networks will start with 192.168.x.x. The other thing that is curious is that if your printer is connected to the PC directly, it wouldn't use TCP/IP to print and therefore might not have a network connection. Another thing you may need to check is that both the PC and printer are connected to the same network, ie with the same SSID.
Jun 16, 2011 | Office Equipment & Supplies
We have a HP LaserJet P2014 that is installed via a USB cable to a Windows XP Professtional Service Pack 3 PC. The printer is shared so that 2 other people can connect to it over the network. However, the...
it sounds as if your network connections are "going to sleep".
This is a "on by default" to save power.
In device manager on each PC right click the network inface card and disable power saving.
If you require step by step instrcutions please ask and state your version of windows on each PC
Oct 06, 2010 | HP LaserJet P2014 Printer
I want to downlaod the Hp LaserJet 1018 driver
Dear User,
Pl open my networkplace in your computer after going(via network) to that pc connected to printer.
when open that pc pl see printer and right click on printer to press connect.
printer is connected to your computer.
Regards,
Ravindra Shah
Jun 29, 2009 | HP LaserJet 1018 Printer
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
Want to connect a Mac laptop to a EpsonStylus Photo R340 printer.
Hi
Try connecting the printer to a different usb port if you have extra port and make sure the connection is direct from printer to your mac
Hope this helps
Nov 14, 2008 | Epson Stylus Photo R340 InkJet Printer
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
Network Connection (LAN) for HP 650C
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
148 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
