Polariod mini mid 4311 tablet
Powered off can/t power back on, screen black and will not charge with any charger. Help plZ!
    Master:
  • 663 Answers
I suggest that you remove the battery from your computer and try charging it. If it turns on then replace your battery . if not, then I suggest that you get it fixed by a tech because it has something with the motherboard.
David
Posted on Jul 18, 2013
leecom72
  • 4806 Answers
SOURCE: acer Aspire one mini laptop
Hi there.
Turn the machine on and look very close at the screen, if you can see a ghost or very faint image on the screen, if you can the inverter or the inverter coil has become defective. Plug in an external monitor to rule out any problems with the laptop itself, if you get a display through the external monitor then it could be a loose connection or the inverter itself.
Post back with the results please.
Good luck and thanks for using Fixya!!
Posted on Feb 18, 2009
SOURCE: my acer aspire one netbook was black screen but the power was lighted, i hear the fun was spinning and the hdd was spinning, please help me, when i powered on it lights up but no display at all a blac
all you do is take out the battery in the back and put it back in and your good to go.
Posted on Jun 29, 2009
SuperTech-11
  • 1591 Answers
SOURCE: my son 7" mini tablet
It's under warranty. Return it and get a replacement. Anything else you might try may void the warranty.
Posted on Feb 25, 2011
  • 998 Answers
SOURCE: Dell D600 boots up fine
If the external monitor looks fine, then yourlaptop's LCD display panel is bad.The inverter brd is part of the LCD display panel.
Posted on Jul 03, 2011
SOURCE: dell inspiron mini 10 won't charge or boot up
Lesson 1: Never, ever buy a computer that does not have a cd drive on it because one day the thing is going to croak and you'll need that drive.
However, your problem sounds like either the power cord is bad or the DC Power Jack where you plug the power cord into the laptop is bad.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Posted on Jun 10, 2012
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Can not move past Android screen HELP
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Feb 05, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
I turn it off and went to it back on and now it want power back on
It is a bit hard to understand your problem.
I assume that you switched it off and is not working.
From experience with other tablets, I would first charge it. (Verify by substitution that the charger is working). Ideally use an external charger and not a computer USB.
Then, if satisfied that the tablet has fully charged, I will press and hold the power on button for up to 30 seconds until the screen stirs.
A better descrition of your problem in clear sentences would help.
Nov 04, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
Android tablet m750b KOCASO problems loading
Turn it off completely. Either by reset or shutdown.
Leave it off.
plug in charger and leave it alone for 4 hours.
Power it back on.
Jun 03, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
