Question about Health & Beauty
Add on to previous question
Getting 8 beeps when switching on.Lights all on horn works.wont move.
    Problem Solver:
  • 5 Answers
All switches work on scooter
Posted on Jul 18, 2013
My horn stop working and when I lock the doors with remote key it wont sound when you lock the doors Forgot to add that it is a 2012 Ford Escape Horn does not work from the inside either. Is it a fuse
Does the horn sound when you press it on the steering wheel if not check for a blown fuse to horn and then if ok see if you have power to horn and then if that is ok run a wire from the battery to the horn and see if it honks.
Apr 15, 2017 | Cars & Trucks
Have electrical issues on a 2004 mazda 3.
I would check every single fuse in the car. Blown fuses can cause weird issues like this. While the initial issue with the mechanic does sound like an alarm problem....the rest does not unless the shop that installed it really butchered the job.
Jul 18, 2016 | 2004 Mazda 3
I have a 2009 elantra and when doors r locked and I hit the starter the car lights blink twice and doesn't start! It was a factory install by Hyundai . The car is an automatic . What do I do? Thanks
I would return it to the installer
My 2012 Hyundai Elantra Wont Start - CarGurus
www.cargurus.com > Questions > Hyundai > Elantra
CarGurusJul 30, 2013 - My 2012 hyundai Elantra GLS would not start this morning. ... I hit my door unlock on mt Key fab and the doors unlocked fromt here I proceeded start my car.... it and it wont turn over just makes a light click. not like a battery issue. .... But if Istart from the zero position on the starter it doesn't start on the first try ...
No horn / No lights when I lock my car - Hyundai Genesis ...
www.gencoupe.com/.../244433-no-horn-no-lights-when-i-lock-my-car.h...
Mar 30, 2014 - 16 posts - ‎8 authors
I do not know what could have caused this but when i lock my car... ... lock yourdoors with your key fob(might have to hit the lock button twice) ... The alarm/horn should start beeping. ... 2010 Hyundai Genesis Coupe 2.0T R-spec in Karussel White.... My lights flash when I lock it, but the horn doesn't sound.
2013 Hyundai Elantra Engine Won't Turnover, Won't Start ...
www.carcomplaints.com/.../Elantra/.../engine_wont_turnover_wont_start...
The 2013 Hyundai Elantra has 19 complaints for engine won't turnover, won't ...
Jan 04, 2016 | Hyundai Cars & Trucks
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
My scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 28, 2012 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
How to fix the horn. or rewire a horn. the previous owner stated that he took out the fuse for the horn because it would not stop beeping . I need the horn to work to pass safety
Apparently the previous circuit of horn is shorted making work all time.
Just check entire wires, relay and horn button in your car for shorted and have them fixed.
Otherwise you need to install new set of horn system ( horn button, wires and relay)
Dec 20, 2010 | 1989 Volkswagen Cabriolet
Horn and brake lights
First if brake lights arent working then the shiftlock wont work. Works off of same circuit. I would check fuses for brake lights and also horn. Not exactly sure on the 92's but good chance theres fuse's inside car and also under hood.
Feb 06, 2010 | 1992 Honda Accord
My mpv 5 turns on and horn works but wont move
Make sure both manual brake levers are in the UP/DRIVE position. They are located just above the footrest between where your ankles would be. If they are both up and there are no flashing lights on the controller, the motors may be bad.
Nov 26, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
35 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
