Question about Jenn-Air Jenn Air French Door Floating glass Cabinet-Depth Bottom Freezer 20 Cu. Ft. - JFC2089H
Jenn-Air Glass Door - How to Clean
Looking for dis-assembly instruction to clean inside of the glass on Jenn-Air model SVD48600P Gas/Electric range w/convection oven
  • 5 more comments
  • Diane Degermanjian Jan 27, 2008
    About a month after I purchased my Jenn Air dual fuel oven, I noticed spill marks between the glass on both ovens. I called Jenn air to complain. They sent a repairman to clean the glass When he first came he said this wasn't covered by the warranty because it was cosmetic. Finally after he made several calls to Jenn air, he cleaned the glass. He said Jenn air normally would not send a repairman to fix this and I was lucky. However, a short time later, the same problem occurred. The glass on the doors look so bad, I hang a dish towel over them so no one will notice. I feel the seal on the door window in not right and this is a design flaw.
  • beework Jul 09, 2008
    Same problem. I've been looking at an oven window with drips between the panes for a very long. Anxious to see replies. Thank you
  • Lady Jarhead Aug 10, 2008
    I've too have the very same problem. Got the same run-around from Maytag .. not their responsibility to "clean the interior glass". OK .. so how does the owner of a $1400 JennAir Stove with "disgusting grimy, grungy spills from last years' Thanksgiving turkey" clean the rotten glass? Maytag does NOT even offer a cleaning process .. nothing in the owners manual explaining the cleaning process, etc. I've owned many, many self-cleaning ovens over the years (even cheap brands) .. and NEVER have I experienced anything like this. Either there is a definite flaw in the assembly of these oven glass doors .. OR .. those of us who have the same "drip problem" were sold an appliance with defective seal .. or something along those lines. Has anyone been successful with disassembling the oven door to get to the interior glass panels? Thanks .. Helen More
  • Trudy McDonald Aug 19, 2008
    Called Jenn-air with the same problem - getting condensation between the oven glass when broiling & it has left unsightly streaks. I feel it is a vaulty seal. Also there is dust & dog hair behind the floating glass. The customer service rep acted very stupidly as though she didn't understand what I was talking about - gave up & emailed them with my problem. The reply was basically "tough sh-t - it's a cosmetic problem & not covered under warranty. We should all band together & do something as a group. This is unacceptable for an oven that is so pricey.
  • Anonymous Sep 27, 2008
    lost owners manual need to know how to work self cleaning.
  • ella138 Nov 10, 2008
    same, problem. Juice from cabbage rolls down the inside between the glass panes. I went through the whole manual and nothing about how to clean this. I have a Jennaire oven. The absolute worse company for customer service. The first and very last Jennaire product I will ever purchase. I will also be ware of all products associated with Jennaire.
  • Anonymous Dec 13, 2008
    On a jenn-air double oven how do a person get the doors off to clean. They will not pull up to release.
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Posted on Aug 12, 2008
  • deanacombs1 Nov 04, 2010
    My problem is dog hair getting between the glass panels on the over door. My husband and I have figured out how to take the door apart to clean it, but it's not easy. It takes both of us to do it and you're afraid you're going to break it the whole time. When I called Jenn Air they acted as if they had never heard of this problem. They advised me not to take it apart but to contact a repair guy. I can't call a repair guy everytime this needs to be done. They should offer some type of fix for this design flaw.
  • AprilFix Nov 29, 2010
    I think that if you can remove the oven door, you can clean inside the glass. My wife doesn't have a Jenn Air double oven like Guest, but a Miele H 398 BP2 double oven with double pane glass doors.
    The door on this Miele has a 20" by 1/2" slot at the bottom. You can easily insert a cleaning rag and use a flat and long ( 1/2" wide by 24") barbecue stick to clean and dry the inside of the glass window. Cleaning is the easier part.
    The real problem is removing the door and re-assembling the door. it takes strength for these door are heavy and hard to hold on to.
    For a Miele oven, the procedure for removing and re-assembling the oven door after cleaning its inside glass surface can be seen on page 77 and 78 of the PDF at this link:
    http://www.mieleusa.com/manuals_pdf/Resi...
    An important point: when reinstalling the door, the hinge must be half cocked, i.e., pushed down to make a 120 degree with the body of the door panel. Since the spring that keeps the hinge cocked is very strong, you will have to insert something such as a 1/4" diameter round metal stick in the space between the cocked hinges and door panel, and then push down the locking clamps to keep the hinge cocked. with both hinges thus cocked, insert into the oven slot reserved for them until they seat well, open the door toward the horizontal, and then lower the locking clamps to lock down the door hinge.
    Henry
    New Friend:
P.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
I lifted the door off and ran hot water through the top of the door which washed all the grease away. I used her kitchen sink that has a pull out faucet, I suppose you could fill a bucket with hot water and do it outside. I slid the door back on to the brackets and put the oven on 400 degrees for 30 minutes. It dried thoroughly and looks pretty clean. Th even had been used a few times after the grease appeared but I would assume if it had become more dry it may have taken repeated hot water rinsing. I hope this helps someone.
Posted on Dec 26, 2010
SOURCE:
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
How do you take the door apart so that you can clean the glass? We have taken out the 3 screws, but it will not come apart.
i just replaced the glass on a jenn air slide in, remove screw on each side, inside the door, near the hinge, lift door off hinges, remove 3 screws on bottom of door. Trim holding glass should now come off. Remember, hinges are spring loaded.
Dec 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Glass inside oven door is dirty. Is it possible to disassemble the door to clean the glass?
You can remove the oven door and dis-assemble it to clean it but you are looking at quite a task to do so.. Most of the kitchen aid brand requires two pins to be inserted into the door hinges while the door is in the open position to allow the door to be open. When you have inserted the pins into the hinge start to close the door and the pressure of the hinge spring will be applied to the pins allowing you to now lift on the door removing it from it's slots in the face of the oven. The hinge will slide out of the oven face.
Once you have the door removed you can begin the task of taking the door apart. Lay the door inside part down on a table or counter, remove the screws from the bottom of the door trim (piece that holds lower part of glass) and remove the trim. Now you should be able to slide the outer glass downwards (some models required side trims to be removed also). Now you can remove the handle assembly and then begin to remove the inner door liner and inner glass package.
Be careful and pay attention to screw size/location.
Take pictures at each step to aid in re-assembly!
Good luck!!
Aug 14, 2010 | KitchenAid KERC607 Electric Kitchen Range
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Dirty glass on oven door
Does your stove have an electric self-cleaning cycle?
If so, do it. I was surprised how well it worked on the glass too!
Remember though it may take 3-4 hours at a very high temperature.
Dec 23, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cleaning front doors
stainless steel cleaner should shine out the metal for you, (always clean with the grain of the metal as not to scratch)and the glass is reg glass, so windex should clean that up
Dec 02, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Clean Inside Door
dont wory kishk help is at hand ,im a profecional oven cleaner ,and would in almost all cases be able to strip the oven door for cleaning .and it want cost the earth
Jun 08, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Refrigerators Logo
2,899 people viewed this question
Top Jenn-Air Refrigerators Experts
jasbo
jasbo
john h
Felizardo Erilla
Felizardo Erilla
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
