Question about Sony HVR-1500 HDV VCR
Firewire port cannot connect to computer using firewaire
  • 53 Answers
U have to select input switchto DV
Posted on Jul 18, 2013
I need a hookup layout for audiofire4 connecting to a Roland XP 80 and to a computer
if your computer has a Firewire (IEEE 1394) port, you can use a Firewire cable to connect one of the AudioFire4's Firewire ports to the computer's Firewire port, then hook up your XP80 to the MIDI ports on the AudioFire4. Connect MIDI Out to MIDI In.
Sep 07, 2013 | Echo AudioFire4 Portable FireWire Audio...
Lost conection firewire ,
Check you have the latest software or firmware drivers from their website at Focusrite.com
Check that the FireWire cable is connected properly.
Try using the supplied power cable.
Try using the other FireWire port found on the back of your Saffire product, and also try different ports (if you have more than one) on your computer.
If you have any other FireWire devices connected, try disconnecting them, as they may be restricting the FireWire bandwidth too much if connectedon the same bus.
NB: You may have more than one FireWire port on your computer. Note that they may be connected to the same bus, even though they appear to be physically seperate. This will be the case if you have a FireWire card with multiple FireWire ports on (all ports on the card will be on the same bus), and is also often the case if you have multiple ports inbuilt on you system.
Increase the FireWire buffer size on your FireWire card, found at C:/Program Files/Focusrite [Saffire product]/Driver/ASIOControlPanel.exe (where [Saffire product] is the name of your Saffire product). Its default setting is 2ms, but you may find that increasing it helps connectivity and will improve audio performance, at the cost of increasing latency.
Mar 09, 2011 | Focusrite Saffire LE FireWire Audio...
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
What wire can i use to connect it to my computer?
You will need a firewire cable and a firewire port on your computer. If you don't have such a port then you can buy a pci firewire port. The firewire port looks like a usb port but its slightly bigger and on the one end is forming an angle.
Please see this link for details and photos.
Firewire Cable
Feb 23, 2010 | JVC GR-DVF21 Mini DV Digital Camcorder
MY Western Digital 1 TB drive operates fine with a USB 2.0 cable but won't even turn on when I connect an ESATA cable or my firewire cable. Am I stuck with USB as my only connection option?
Some of it may depend on the controler you are using. some of the VIA chipset ones are not all that good and overheat a little causing ptoblems.
Also make sure you do have the firewaire card in your computer.
Many cases have the connection on them but no card inside.
Same for E-SATA.
Double check inside first !
Sep 08, 2009 | Western Digital My Book Essential Edition...
FIREWAIRE OR USB?
This camera appears to be firewire only, according to the comparison chart on sharp's website:
http://sharp-world.com/products/viewcam/compare2003.html
They call it iLink, which is Sony's term for iEE1394, Firewire is Apple's term for it.
Sep 16, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Sony HVR-1500 HDV VCR Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
