Question about Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter
Pride gogo elite traveller plus,wont go.
Brand new out of box,Batteries are charged,but getting 8 beeps.
3 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: Where can I find a
Contact Pride Mobility at 800-800-8586, they are usually around $20.
Posted on Nov 09, 2010
gfreed100
  • 60 Answers
SOURCE: Priderear wheels intermittentant response and sometime fail to engage?
First it could be the brake switch. This switch is located on
the back side of the motor. Its usually apart of the freewheel assembly. This device gives me all kinds of trouble. It can get moist and even wet when you use the scooter outside. This causes the mechanism too get stiff. So i spray it with pure silicon spray. WARNING Do NOT USE WD40 eats some plastics.
IT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
Posted on Aug 16, 2012
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Need a repair shop to fix my gogo elite
This is due to the controller shutting down. Make the brake leverin the on position
Oct 08, 2014 | Pride Mobility Products Go-Go Elite...
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
Aug 17, 2014 | Pride Mobility Products GoGo Elite...
Beep codes beeps
Contact a local DME dealer in your area or, on the internet. Give them your serial number for the GOGO to order a new solenoid brake. It is important to have your serial number when ordering to ensure you get the correct part.
Jun 07, 2014 | Pride Mobility Products GoGo Elite...
Fault finding
maybe the leds are burnt out
Oct 17, 2013 | Health & Beauty
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter  Logo
35 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
