I have a Maxell GENpro 500Gb hard drive and I re formatted it without saving the software to desk top. How can I find the software to re install?
SOURCE: i need to format my
try using the diskpart application which is in windows
type
list disk[enter]
which should then provide you with something like this
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 466 GB 8033 KB
Disk 1 Online 4 GB 111 KB
your pen sticks size should reflect the actual size of penstick to help you identify it, in this case above the 4 GB one so its disk 1
ensure you do you may delete the hdd if not careful
then type
select disk 1
then
clean
then
creat partition primary
then
select partition 1
then
format
SOURCE: maxell genhd 500gb formatting needs
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
click on your usb drive select format
if you need more help with this post a reply
hope this helps you
SOURCE: maxell 500gb formatting problem
another way
right click on your usb drive select format
hope this helps you
SOURCE: maxell max data 1tb hard drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working
ports (com&lpt) right click update driver
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
hope this helps you
another way
hope this helps you
another way
hope this helps you
