Question about HP DeskJet 1220c InkJet Printer
HP 1220c problem
HP 1220c ink light is flashing, replacement of cartridge or cleaning cartridge does not solve problem when you lift the cover it indicates a problem with the black cartridge
  • Anonymous Mar 29, 2014
    wont accept ink cartridge
No manual. i replaced both cartridges. i didnt read instructions for installing cartridges. failed to remove tape.tape on both cartridges are removed.i can now print again.
Posted on Nov 10, 2007
  • 32 Answers
Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
Posted on Aug 28, 2007
SOURCE:
I have problem that on my hp 1220 deskjet ar blinking all of buttons. I mean buttons for power, buttons for parer and button for cartrige and don't printing anything. How can I fix this?
Hi, This is the problem of cartridge mostly. You may need to replace the cartridges. Check the cartridges and make sure that the cartridges are not blank or not get the ink dry. Clean the printing head 2-3 times. Align the cartridges and clean the nozzles also. Reset your printer and remove all pending print job. If it doesn't solve your problem then replace the cartridges.
Sep 26, 2011 | HP DeskJet 1220c InkJet Printer
My power light ,resume light and ink light keep flashing? i tried to print photo and kept sounding like it was printing but no picture and lights started flashing
One of the ink cartridge is defective. If you lift the front cover, the cartridges stop position You will indicate which of them is defective (by the drawings on the printer).
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 26, 2011 | HP DeskJet 1220c InkJet Printer
Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Resume button will not stop flashing.
The HP series of printers you have can be finiky when cartridges are swapped. Use an old toothbrush to very gently clean the contacts behind both ink cartridges. Carefully wipe off the contact strip on the back of each cartridge. repeat this till the cartridges are properly detected. close the lid after each attempt!
Nov 10, 2009 | HP DeskJet 895cxi InkJet Printer
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the...
IT COULD BE THAT THE INK SERVICE STATION CANNOT MOVE BECAUSE OF WATE INK.ALSO ADD SOME SEWING MACHINE OIL TO THE SILVER SLIDE BAR THAT THE CARIAGE RUNS ON.DONT GET OIL ON ANY OTHER PARTS
Jun 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
Epsom dx4450 how to change ink cartridge
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Sep 16, 2008 | Epson Aculaser C1100 Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
913 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
