ASRock G31M - No video output
ASRock G31M motherboard Corsair CX430 PSU GEIL DDR 2 1GB x 2 Intel Duo Core E4800 3.0ghz CPU
    Brigadier General:
  • 3,400 Answers
Paul it should be a VGA-PORT back on the I/O-shield,beside the USB.
Posted on Jul 18, 2013
Intel fw82801db
on your board theres is a spot where the fan from the cpu goes it saids cpu fan on the board near by cpu socket
Aug 06, 2013 | Asrock Computers & Internet
Asrock gm31-gs optical drive
Hello here is the homepage:
http://www.asrock.com/mb/Intel/G31M-S/?cat=Download
Update any drivers for your windows system, if any missing, or you could have a faulty drive.
Good luck
Jan 05, 2013 | ASUS P5K WS INTEL CORE2 EXTREME/CORE2...
What is the purpose of intel tv wizard in asrock G41M-VS3 motherboard
The Intel TV Wizard is there to assist you in connecting your PC to your TV. It comes with most units that has a Intel Video card or embed Intel video chipset. You may choose to skip this process entirely or follow the steps if you wish to connect your PC to your TV.
Dec 23, 2012 | Intel Asrock G41m-vs3 R2.0 Motherboard...
Asrock g31 m motherboard will only post if only one ram slot occupied , will not post if both slots are used , identical matched pair of ram ddr 667 800 mhz crucial ballistix both tested in another ri
I did some research. You didn't say what density the RAM was, but everything I can find on the Ballistix 800 MHZ DDR2 states that it runs at 2.2V. The standard for DDR2 RAM is 1.8V. You motherboard has both and AUTO and manual setting capability for memory (DRAM) voltage. It is possible that the AUTOP feature is not detecting the need for 2.2V, and that with only one DIMM installled, the memory marginally functions, but with the extra loading of the second it will not. Boot the system with the single DIMM, go to the BIOS, and set the DRAM voltage manually to the 2.01V setting (Verify by the part number of the RAM with the CRUCIAL website that is uses 2.2V before doing this). Once you have changed the voltage in BIOS, shut down and add the second DIMM and see if things improve.
Jan 16, 2012 | Asrock G31M-S Motherboard
Hi, I am experiencing problems with the asr-p55-deluxe motherboard. i have fitted all my componets to the motherboard and when i try to boot up the system it shows an E8 on the debug on the motherboard...
First thing to check is that you have good contact between the CPU and the heat sink and of course the fan is spinning one heat sink and video card. Cycling like you are encountering can be caused by CPU overheat. I had a seized video card fan take out a P4 Asus motherboard.
This states your RAM may not be fully seated. You have to press hard and make sure you can see the lock at the ends drop in.
https://forums.evga.com/P55-SLI-Debug-Code-E8-m5003.aspx
You aren't the only one to get the E8 debug code :>)
https://www.google.ca/search?q=asrock+p55+deluxe&ie=utf-8&oe=utf-8&gws_rd=cr&ei=4RPbWKKnEIvVjwTlpqDgBw#q=asrock+p55+deluxe+E8&*
The other things that cause problems like yours are incompatibilities with components added, for instance I had a system that gave all sorts of problems. When we contacted the wholesaler, they said "yes, that board doesn't work with that video card for some reason". Used a better video card and it was fine.
All your components seem on spec, but my only concern is that you are only putting in 4Gb RAM when the board will take 16Gb.
http://www.asrock.com/mb/Intel/P55%20Deluxe/index.asp?cat=
Contact their support.
http://event.asrock.com/tsd.asp
Mar 29, 2017 | Asrock P55 Deluxe (4711140875910)...
Want to know that "ASRock G31M-S" is compatable with Nvidia 9500
Your new card maybe faulty or you might need a larger Power Supply Unit (PSU),, if its just started to happen...
Jul 30, 2010 | Asrock G31M-S Motherboard
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
May 05, 2009 | ASUS Computers & Internet
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
