Xerox 550 fuser counter reset
Thy fuser assembly needs to be replace
  • 1056 Answers
SOURCE: how to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Aug 28, 2008
jtuminaro
  • 56 Answers
SOURCE: Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Posted on Jan 14, 2009
  • 13 Answers
SOURCE: Reset maintenance counter
To reset the Maintenance counter yiu need to go into Config Mode.
Power on the printer while holding the 2 & the 6 button.
You will see the maintenence counter and can reset it from there.
Posted on May 28, 2009
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
  • 5 Answers
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
Posted on Aug 12, 2009
WorkCentre 7345 Fuser Assembly replace soon showing. please how i reset this
Replace the fuser assembly.
The fuser melts the toner ink onto the paper.
As such, it's a vital part of the printing process.
Mar 25, 2015 | Xerox WorkCentre 7328 7335 7345 7346...
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox 6280 gets error message replace fuser kit, it was replaced and still has the same message
This is an easy one.
The original fuser supplied with the printer DOES NOT have a counter chip. Instead, the PRINTER assumes that when the number of pages printed reaches the level at which the fuser needs to be replaced, the printer issued the REPLACE FUSER message.
If you replace the fuser with another that has come OUT OF a new printer (i.e. a 'PULL' from a new unused printer), since it has no counter chip of it's own, the printer assumes the fuser pagecount is the same as the printer pagecount (because there is no information to read from a fuser chip), and still wants the fuser to be replaced.
A new REPLACEMENT fuser from XEROX, or a CORRECTLY refurbished fuser WILL have a counter chip, and therefore clear the REPLACE FUSER message.
Nov 28, 2012 | Office Equipment & Supplies
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Have a BIZHUB 550 with a C-3724 error on it. I had to select the 450 below as the 550 is not listed.
Fusing abnormally high temperature detection
The fuser section reached a temperature outside of safe operation. You can reset the error by: Turning the main switch off, leave the operation panel switch on, hold down the utility/counter key and turn the main switch on. As the screen loads you will see a black dot in the top right corner, at this point you can release the utility/counter key. The machine will take a minute to load. When the screen loads you will have a key that says "Trouble Reset" press it and you will get a "OK" message. Turn the main power off for 10 seconds and turn back on. If message returns you must replace the fuser. Attempt Trouble reset again at your own risk!! Fusers are a Fire Hazard
Apr 27, 2010 | Konica Minolta bizhub C450P Laser Printer
Fuser error code u4
You would have to replace the fuser to resolve that code.
Jan 06, 2010 | Xerox Phaser 4500 Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
Oct 13, 2008 | Xerox Phaser 4500 Printer
XEROX 7300
Sounds like you have had a fuser roll failure.
Could be either the heat or pressure roll failure from your description.
That is an easy replacement. You can call 1-800-835-6100 and order one. It is on the left side of the machine, The area that is very hot. It has 2 thumb screws to remove and replace it. Only issue would be, the fuser has a replacement count on it that needs the proper laptop hooked up to it to reset the count. Although it will not fail to run without the count reset, once the fuser count reaches 100,000 images in the counter, it will shut the machine down until it is reset.
Mar 18, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
27 people viewed this question
jasbo
jasbo
