Question about Pool & Spa
Zodiac Genius gets stuck
I have a Zodiac Genius and it keep on getting stuck in all the corners of the pool,after releasing it from th corners on its way to the next one it climbs out above the water line I have done every thing shortning the pipes,adding pipes,ajusting the input flow,backwashed etc. Please HELP
3 Suggested Answers
  • 106 Answers
SOURCE: get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Posted on Jan 15, 2010
jharwell668
  • 640 Answers
SOURCE: My Zodiac G4 is constantly getting caught in the
have you tried adding hose weights? The hose is often a problem with these pool cleaners getting caught on corners or steps. You might also want to add a Wheel Deflector (PN W83278) if you have adjusted the hose and it still gets caught. If it is hanging on ladders, consider adding a Ladder Guard (#W24000). These are both optional parts that should prevent the problem if added.
Posted on May 09, 2011
Gets stuck in corners of pool
Try re adjusting or re positioning the hose weights.
Feb 21, 2015 | Zodiac Baracuda G3 Automatic In Ground...
Zodiak G4 Get stuck in corners steps ect.
Check a couple things when these pool cleaners are getting stuck on steps and in corners. Is the correct length of hose being used? It might be necessary to shorten. Make sure that the ideal flow is being achieved. Add hose weights 3 feet from the cleaner head. You might need to also install a wheel guard (part # W83278). This wheel delfector will also work if the cleaners are hanging on the ladder.
Apr 14, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Keeps getting stuck in corners
There are several things that you can try if your pool cleaners getting stuck at corners. First, make sure that the cleaner is getting the proper water flow and adjust it if necessary. Also, make sure that you inlets are adjusted so that they are pointed down and at the center of the pool. This will ensure that the cleaner is pointing in the right direction. Check your hose weights to make sure that they are correct. You will know they are right if the cleaner is sitting at a 45 degree angle with the pool's bottom when resting.
Nov 20, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac G2 gets stuck at far end of pool in two corners. Each time I have to pull the hose to get it out, then its fine. Anything I can do to stopit getting stuck in the first place, please?
The biggest cause of this is current in the pool driving the cleaner to the corners. You propally just need to change the direction of the eye balls on you returns to the pool. Face them down the pool wall or just in another direction to break up the flow of water in the pool.
Oct 07, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My zodiac baracuda gets caught up in the corners of my pool constantly. What should I do?
If these pool cleaners are getting stuck on corners or other obstacles, try these solutions. Try using Pool Pulse to lower the flow. If you are getting too much flow, the cleaner will stay along the edges of the pool and in corners. You might also need to adjust hose weights. You can adjust your return flow lines in the pool. If they are directed toward the corners, try moving them down and center to direct the cleaner in the correct positions in the pool.
Aug 13, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac has suction but doesn't move
With these pool cleaners, that is often a problem with the flapper. Check the flapper to be sure that no debris is stuck. Debris can halt water flow and movement, making your cleaner get stuck.
Jul 11, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Get stuck in the pool corner
Jan 15, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda gets stuck
Usually this can be fixed by redirecting thr returns in the pool down the wall or anywhere that will break up any currents in the pool.
Dec 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Stuck in corner
Try adjusting your returns to change the currents in the pool and see if that helps.
Oct 13, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pool & Spa Logo
60 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
