Question about Polaroid PoGo Digital Photo Printer
Canon error e301- 001 main - Polaroid PoGo Digital Photo Printer
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Error e202-0002 for canon imageclass mf4412 and showing turn the main power on
Please follow the link below and it will show you what is happening.
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/Canon-MF4412-laser-printer-error-quot-turn-the-main-power-on/td-p/40847
Nov 08, 2014 | Office Equipment & Supplies
E351-0000
E351: Error PCB ECO. Communication error between the PCB and the PCBECO main driver during startup.
Turn off main power and check the main controller PCB (primary, secondary), thenturn the main power.
Check in the back of the machine the main controller PCB (Main) make goodconnection with the PCB ECO-ID: help with image processing.
Hoping this is helpful message ... GOOD LUCK
Apr 28, 2012 | Canon Office Equipment & Supplies
Canon MF4412 turn the main power on E000-0000
Apr 18, 2012 | Office Equipment & Supplies
Canon image class mf4412 error code 301-0001
good affternoon i want the salution of canon printer 301-0001 eror
Mar 27, 2012 | Canon Office Equipment & Supplies
Error 6000
Canon Pixma MP150's "error 6000" will be encountered once there's a malfunction on the parts below.
- Timing sensor ***'y - Timing **** disk film (Main unit) - Feed roller ***'y (Main unit) - Platen (Main unit) - Logic board ***'y - Paper feed motor (Main unit)
This is not DIY, I would advice you to look for a qualified Canon Technician or send it in to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jun 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error e202 in canon 6330
E202 That is scan problem scan switch scan motor or may bi image processor board.do not forget to rate solution.by MIAN JEE
Feb 20, 2009 | Canon imageRUNNER 5570 Copier
Polaroid PoGo Digital Photo Printer Logo
32 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jerry Umali
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
