Question about Vehicle Parts & Accessories
3f engine landruiser 3f engine thermostatat not openning in car when runnuing engine overheating took thermostat out put on the stove in a pot of hot water it opens why isnt it openning in the car and yet it opens in hot water on the hot plate in a pot??
  • Vehicle Part... Master
  • 14,036 Answers
Replace thermostat use the right thermostat rating 195 degrees and make sure vechicle has enough coolant in the system not too much air.too much air in the cooling system where engine coolant sensor cant get hot in the coolant where pcm cant get signal to turn on cooling fans vechicle will run hot.the ECT sensor and thermostat need to be in hot coolant to work right.
Posted on Jul 18, 2013
Walker mower gasoline engine. Kubota 21hp. Afther 5min working the engine get overheated .
If you have Radiator fluid and it overheats... most likely thermostat is stuck closed. Change thermostat. To test it remove the thermostat, put in a pot of water and boil on the stove you'll see it open it if won't bad... if you just replaced it .. my may have installed it backward. Either case test if all good, clogged radiator, if good then bad pump.
Hope I helped
Mike
Apr 21, 2018 | Cars & Trucks
2012 Buick Lucerne overheating changed thermostat still overheats
look some cars have two thermostats. or it could be your waterpump not circulating water. check the belt that drives pump. test your termostat! take it out. connect a thin long wire to the top and plop it in your kettle while boiling. or into a small pot of water on the stove. when it gets hot enough you will see it open. no a little bit but alot. you can also checks its opening temperature to the previous one make sure they exactly the same. good luck
Jul 06, 2016 | Buick Cars & Trucks
,y 84 nissan 30zx 2+2 is overheating.water pump works took thermostat out completely. there was no leaks in any hoses is this ok
Was the thermostat bad. To check it,put it in pot of water and boil on stove and see if it opens at 180 degrees,if it doesn't then it's bad.Are you sure water pump is circulating,doesn't have to leak to be bad.Is your radiator flowing good,not clogged and do you have a blown head gasket,check oil to see if it is milky.Is white smoke coming out of exhaust pipe.Also how does your spark plugs look like,not oily,I hope.
Sep 16, 2013 | 1984 Nissan 300ZX
04 x-type no heat, vehicle overheating, I changed thermostat, still no heat, and vehicle still overheating, I have no fluid,lose, fans are operating normally
I had the same problem with my daughters truck. Changed everything finally changed the radiator, that was it.
Nov 13, 2011 | Cars & Trucks
How can i tell when my thermostats bad on my 1999 jeep grand cherokee 4.7l
The best way to test it is to remove the thermostat, and then boil some water in a pot, drop the thermostat into the water and watch how well the thermostat responds. It should open up to the full open position very quickly and if it is slow or lagging to open up, or it does not open fully then replace the thermostat.
May 17, 2010 | 1999 Jeep Grand Cherokee
My car was overheating so i took off the thermostat and replace a hose that was leaking but now car hasn't overheat yet b water comes out through reservoir tank what could be the problem now?
the water is getting to hot even though its not overheating because you need a thermostat to trap the water in the radiator to give the water a chance to cool down then the thermostat opens and the cold wanter enters the motor and the hot water in the motoer enters the rad. to cool down. with no thermostat, this doesnt happen it just circulates and warm up to the temp it warms up to and is at the same temp in motor and rad then to hot will come out the overflow, as a resualt, you will wind up losing antifreeze then wont have enough antifreeze in your engine then will damage your engine.Put a thermostat in and a water pump. fix it right or you will damage your car.
Dec 28, 2009 | 1995 Honda Civic
Temperature gauge going to the red when driving
put some water in , find out if you have a leak , ie, leaking water pump or pipe , is it overheating , is the oil got white sludge under the cap , a sign water is getting past the head gaskett , check out these items first
Nov 20, 2009 | 1998 Ford Escort
My 96' gsxr750 stalls when it gets hot at idle, say at a red light for instance. it needs to cool down for about 15 minutes before restarting.need help!!!!
So what you need to address is the overheating issue.
First check radiator fluid while engine is up to operating temperature, add if neccessary.
Then check to make sure your fan is kicking on when your bike starts to get hot. If your fan doesn't kick on that is your problem. If your fan does kick on and your fluid is full move on to next step.
Remove thermostat from bike and test to see if its working properly. You can put the thermostat in a pot of water on the stove. Use a candy/meat thermometer to see at what temp the thermostat opens up. It should open at around 180 degrees.
If the thermostat doesn't open up before the water starts boiling that is your problem. Or you can just change it because your bike has sat for 1.5 years and now the thermostat probably is sticking causing no radiator fluid to enter your engine to cool it down.
Hope this helps,
AadoubleA
Don't forget to give me a fixya rating, and THANKS!
Apr 05, 2009 | 1996 Suzuki GSX-R 750 T
Coolant bizarre behavior
if car doesn't run hot with no thermostat...you may be air-locking system when installing thermostat. I always fill the engine block up to the thermostat housing to make sure that engine is full of fluid ..then install thermostat...spring facing down..thenfill radiator making sure car is running so as not to air lock system ...run until top hose gets warm ,showing that your thermostat opened
Nov 23, 2008 | 1998 Chevrolet Cavalier
Thermostat
It should open when it gets up to the opening temperature. Better way to test it is to put the water in the pot, hot from the tap, and put it on the stove. Put a thermometer in there too so you can monitor the temp. Drop in the thermostat, then heat the water on the stove. When it opens, note the temperature that the opening occurs at - then you can see if it's opening at the correct temperature. If you put it in boiling water, it'll open - but you won't know if it opened at the right temp.
Aug 17, 2008 | 2000 Volkswagen Golf
Vehicle Parts & Accessories Logo
227 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
