Question about Danby DPAC10031 Air Conditioner
I need a replacement for the water tank quick connect into the cabinet quick connect
3 Suggested Answers
SOURCE: Need new external water tank quick release for Danby DPAC9030
You can order it from Danby directly (you can get their contact online from the Danby website). They cost like 4$+shipping, I had to buy one last summer. They ship to Canada and the US.
Posted on Jun 25, 2009
SOURCE: Remove Water Tank
I have a five yera old Danby portable unit model 10030. The machine makes a beeping noise and the read out says water tank needs emptying. On inspection both the internal and external tanks are empty. I disconnect the unit and then reconnect and it will condense for a while before the beeping strts again and the fan only blows. Can anyone help
Posted on Jul 20, 2009
Water not heating
Dish washers only use water supplied from the hot water side of the pipes under the cabinet or sink, so if you installed the dishwasher yourself, be sure that you ran your inlet water line and connected it to the hot water side, and not the cold water side. The dish washer has heating elements inside the machine to dry the dishes, not heat the water. If this is hooked up correctly and you are still getting cold water to heat the dishes, the problem may be that the unit is too far from the hot water tank. In that case, you may need an auxiliary hot water tank installed near the dishwasher under the cabinet. They make small tanks for such purposes.
Dec 14, 2014 | Dishwashers
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
My 20 gallon campbell hausfeld wont hold air.what could be the problem
Joe:
There is an air leak somewhere in either the tank connections or the hose connections. Look at the tank and find the tube that runs from the top of the compressor to the tank (usually a brass line). grab a spray bottle and fill it with a soapy solution (dish washing soap and water is fine). Disconnect the rubber air hose from the tank (at the quick disconnect) and start the compressor. Spray the dishwashing solution on the brass line end fittings at the compressor head and the tank connection, and the quick disconnect fitting and where the quick disconnect connects to the air tank. If you see bubbles being blown, that is where your leak is. Also connect the hose to the tank and check your hose for leaks with the soapy solution. Once you find where the leak is, you can tighten the fitting or replace the faulty gasket or hose.
May 25, 2014 | Air Tools & Compressors
How do I replace water lines from bathroom sink to outside drain lines
Supply or drain? The supply lines will be routed either behind cabinets or through the floor. You can use a sharkbite fitting to connect the new water line to the old and then pull until you have reached the location to be connected. Then install the required fittings to properly connect. The drain lines do not go directly outside. They are directly plumbed into a holding tank and then the holding tank is plumbed out to a valve and then a drain fitting.
May 03, 2014 | Dutchmen 2013 Kodiak 240BHSL
How to clean/pull out reservoir in bottom of fridge?
If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
1. Remove crisper drawers from fresh food compartment.
2. Remove hex screw holding water tank to rear
bulkhead.
3. On rear of cabinent remove hex screws holding water
valve cover plate.
4. Remove plate and tubing away from cabinet to expose
water valves and tubing.
5. Disconnect water tube from secondary valve coming
from water tank, remove compression nut from tubing.
6. On front of unit remove toe grill and disconnect water
coupler going to water dispenser
7. Remove compression nut from water tubing on cabinet
side of connection.
8. From rear of cabinet pull water tube out of conduit
going to dispenser.
9. From inside of fresh food compartment pull tubing up
and out of cabinet to complete removal of water tank.
10. Reverse procedure to reassemble.
To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Jun 19, 2009 | Danby DPAC8020 Air Conditioner
Jun 19, 2009 | Danby DPAC9030 Air Conditioner
No water comes out of washer, hot or cold. I disconnected the hoses from the back, checked the water presure and the screens, looked good. I poored some water in and used the spin cycle to check the drain,...
Could be a bad water valve. to access the valve you need to flip up the conrtrol panel. Get a putty knife and release the spring clips on each end and flip up the panel. Pop the cabinet clips and tip the cabinet forward so you can get to the water valve. I generally just unplug the quick connect and power up the valves with a test cord. 3 months old it ought to have a frigging waranty on it anyway.
Jun 14, 2009 | Washing Machines
Suspect there is dirt in the cold water side of solenoid. Won't stop running. Need to remove back of washer so I can get new one. How do you remove back. A diagram of parts and numbers would be very...
Cabinet removal is quite simple. You flip the controls upward to expose the Sclips which hold the cabinet. You release the lid switch quick connect and tilt the cabinet forward. Lifting it out of the way.Then you can easily replace the water inlet valve.
May 16, 2009 | Whirlpool LSQ8543J
Danby DPAC10031 Air Conditioner Logo
35 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
