??? My LG 50PN4500 TV has a strange one-time issue, I turned it on last night (was on standby) and a full screen "shadow" pattern of squares appeared? They were gray but I could see the colour programme still playing like normal behind them? Squares were about 1.5cm squared, each one was spaced about 2cm away from it's neighbouring squares- it was literally a completely symmetrical see-through pattern covering the whole screen. Anyone know what it was? I did change channels and run the DVD player and the squares stayed put. I switched the telly off to standby after 15 mins, waited 5 mins, turned it back on and the squares were still there for about 2 mins, then they disappeared as soon as they had appeared in the first place- weird. Turned telly on tonight and zero squares anywhere, time for me to buy a new telly? Or can it be fixed? This ones only 18months old :/ thanks
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Mar 12, 2017
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Posted on Jan 02, 2009
My LG 50pn4500 tv
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 22, 2016 | LG 50" 4500 Series Plasma HDTV - 50PN4500
How to fix plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 11, 2015 | LG 50" 4500 Series Plasma HDTV - 50PN4500
I have a Mitsubishi 52628 that has a strange pattern on the left side of the screen.
I had this strange occurance too. It appeared right after I connected the antenna wire so I changed to another style input and got the full screen shot. i did not investagate the input on the tv further as I had other connections i was able to use. I hope that helps with yours.
Jan 31, 2012 | Mitsubishi WD-52628 52" Projection HDTV
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Problem with LG LCD TV, model MW-60SZ12. there is a yellow shadow at the middles and some blus shadow starts from the right corner and goes down to the bottom of the screen. it stays on all the time even...
We have this problem too, emailed LG Australia where we bought the TV from (heard that this was a warranty issue) and they told us to take it to an authorised repairer here in NZ. We telephoned 2 repairs (we are rural and carting a 5 foot TV about the place isn't easy) and the word is the part is no longer available and the last time the repairer undertook the work it cost over $NZ2000 to fix. We are disgusted that our very expensive TV hasn't lasted very long, nor has available parts.
Jan 16, 2011 | Televison & Video
My TV was working fine when I turned it off last night. When I turned it on tonight the picture both on TV channels and when I played a DVD was hidden behind a kind of patterned grey curtain. Sometimes I...
This problems is the board call the T-CON decoder board is the causes and the problems.This board is dying.The T-CON decoder board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Jan 13, 2011 | Sharp LC-32D47UA 32 in. LCD HDTV
I GOT A SONY THAT I BOUGHT LAST JUNE OF 2004 NOW I CANNOT POWER IT'S JUST SAY STANDBY
1. Will it turn on at all?
2. How many times does the standby light blink? Is it consistent and continuous?
3. Did the screen do anything strange before this happened (did it turn pink? Any lines across the screen?
Answer those questions and I'll try to help you.
Nov 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
