Question about Epson TM-T20 Thermal Receipt Printer - Dark Gray
No Copy Count Control
Greetings All,,, I have installed Epson Advanced Printer Driver 5 in a client's machine , but there is option for Copy Count is faded and I cant make it print more than one copy each time, although that option was there in the version 4 of the driver. how can I set the printer to print 2 copies ? thanks to all in advance.
SOURCE: printing problem on Epson LQ 2070
check on the Bios of the computer try to set the parallel mode to ECP enhanced compatibility port, because some dios are on epp mode
Posted on Jan 07, 2008
  • 15 Answers
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Posted on Mar 01, 2009
  • 63 Answers
SOURCE: Mac OS 10.5 Leopard
You will nee the latest version of Print CD version 1.6 or above. Version 2 can now be downloaded from the Epson website free of charge. You will also need the latest Easy Print Module and latest printer driver.
Posted on Aug 19, 2009
SOURCE: epson tm-t88II prints the second copy after i restart the pc
We have a TM-T881V Printer and it has stopped printing on the paper. I am not seeing an ink cartridge or cant find it. Any suggestions?
Posted on Apr 16, 2010
SOURCE: Greetings,\r\n I have a Epson TM-88III connected
I have same problem, but with straight parrallel port, I have to delete the driver and reinstall it works until i restart the PC. I still trying.
Posted on Dec 21, 2010
I have a Epson TM-T88III as a networked receipt printer, we have a new machine that has windows 7 and I can not get a driver to install that works. Any suggestions?
Dear Clark, it seems you have a lot of money when you suggest to waste a printer 240€ value.
The solution:
Link www.epson-pos.com and register, after that, follow this path:
Thermal line printers
Choose your model
Epson Advanced Printer Driver for TM Series (the first option for Windows7)
Install it, it Works properly.
Jun 29, 2010 | Epson TM-T88III (C420863)
My hplaserjet 1320 prints multiple copies when printing Excel Doc
The best thing to do as a starter is:
1. uninstall the print driver THEN
2. download the latest version from the manufacturer and install it
This rules out the driver as the cause of the problem
1. Go to printers
2. Right Click on the Printer HP Laserjet 1320
3. Click on Printing Preferences
4. Click on Advanced
5. Double Click (to open) on Paper Output
6. Ensure that COPY COUNT is set to "1"
If it is already set to one, trick the system a little:
1. set it to 2 and save that setting
2. then go back in and set it to 1
Good luck
Mar 15, 2010 | HP LaserJet 1320 Printer
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Dec 24, 2008 | Epson TM-T88IV Label Printer
My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Dec 03, 2008 | HP LaserJet 1320 Printer
Driver for printer epl 5900l with os vista
In Win7.Ultimate.x86 ver 7600.16385.090713-1255, go to the Control Panel->View devices and printers, right click on “Epson EPL-5900L Advanced”, select printer properties, click “OK”, select advanced, set “print direcfly to the printer”.
It worked!
Mar 16, 2008 | Office Equipment & Supplies
Epson dx8450 printer
Hope this helps. Install the nearest series printer driver it maybe available with Vista (DX8000 series). Other option I used to deal with my client with hard to find drivers, I used printer driver emulation. Hope you still have the manual to check with the printer drivers emulation. Last resort, is to find nearest Epson national distributor or Authorized Service Center. There might however extra fee if needed for the CD copy.
Best regards,
Rosener Guyano
Feb 02, 2008 | Office Equipment & Supplies
Not install for windows vista
In any Windows environment, the printer itself becomes a dummy terminal and all changes to the printer will be over-ridden by the application or the operating system.
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE: Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
To make adjustments to the output quality and speed in Windows Vista, please do the following:
1. Click on START, CONTROL PANEL, and PRINTERS.
2. Right click on the printer icon, and choose PRINTER PREFERENCES.
3. Click on the ADVANCED button in the bottom right corner.
4. Click on the GRAPHICS option and click the down arrow.
5. Choose the lowest number to drop your resolution and pick up your speed.
6. Click on PRINT FEATURES and choose the option HIGH SPEED ON.
7. Click OK to apply the changes.
8. Once again right click on the icon for your printer, and choose the PROPERTIES tab.
9. Click on the ADVANCED tab and click on the button called PRINT DIRECTLY TO THE PRINTER.
10. Click APPLY (if applicable) and/or click OK to apply the changes.
The driver you are using is a graphics driver and may not have the adequate speed for your purposes. In Windows VISTA there are more basic drivers which respond better to custom page sizes and speed adjustments. Windows also has a driver called GENERIC TEXT ONLY which is made as a universal driver for all printers just for speed. To add in either of these drivers please do the following:
2. In the left hand column choose the option ADD PRINTER. The ADD PRINTER WIZARD comes up, click on NEXT.
3. Select Add a Local Printer.
4. Click on NEXT.
5. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
6. In the next window select EPSON under Manufacturer. Please use the guide below to select an appropriate Emulation driver. If you wanted to install the Windows universal driver, choose GENERIC under Manufacturer and choose TEXT ONLY, click NEXT.
EPSON LQ SERIES (136): Used for LQ wide carriage printers
EPSON LQ SERIES (80): Used for LQ narrow carriage printers
EPSON LX SERIES (136): Used for LX wide carriage printers
EPSON LX SERIES (80): Used for LX narrow carriage printers
EPSON FX SERIES (136): Used for FX wide carriage printers
EPSON FX SERIES (80): Used for FX narrow carriage printers
7. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
8. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
9. Once the test page has printed, click FINISH to exit the wizard.
Jan 22, 2008 | Epson LX-300 Matrix Printer
Epson TM-T20 Thermal Receipt Printer - Dark Gray Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
