Question about Cooler Master Office Equipment & Supplies
Slow down electric submeter
I am using very less electricity at my home but my bill dose comes Rs.1100 per month..plz suggest me that how could i get reduce my daily electric consumption??
ceiling-fans
  • 20 Answers
SOURCE: 240v electric motor
Reducing the voltage is what you want to do -- this will effectively reduce the speed, without creating an annoying hum.
That said -- 110v is too low. Start higher. Half the voltage doesn't equal half the speed.
Posted on Jun 17, 2008
  • 234 Answers
SOURCE: Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Posted on Mar 14, 2009
aguywithfeet
  • 20 Answers
SOURCE: How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Posted on Mar 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: Reduced RPM and smell smoke
Could be electrical problem, (brushes burnt, armature grounded or bearings starting to seize up) I don't think that I would use it till the problem is fixed. Could cause or create more expensive repair. Let me know and I will try and help
Posted on Jul 20, 2009
  • 123 Answers
SOURCE: my electric bill is usually $200 a month I got a
These electric resistance heaters will use allot of electricity. My suggestion is to get rid of it. It uses more electricity than a regular heater. Too often people believe that these are more effecient, but the fact is they are not. That would be a good reason the electric bill went up. It costs about 100 a month on average to use on of these so if you have 2 then it costs 200 a month.
Thanks.
Posted on Jan 28, 2011
My electric bill is usually $200 a month I got a presto heat dish and just paid my electric bill $545 what can i do?
Thanks.
Jan 27, 2011 | Presto HeatDish Compact Heater
Hi,\r\nat the beginning of October, i bought a Whirlpool dryer - AWZ 3477, and use it about four times a week. i mainly use the "cupboard dry" function. i tend to put the dryer on at night, go to...
you mean the dryer required more power supply.you have to be careful with these solution cos it very hard to understand. Power could be off- - Check the voltage at the outlet with the VOM.Timer or thermostat could be bad -- Follow same tests as listed above.Terminal block could be bad -- Use the VOM to check for voltage at the terminal block. Be very careful here, as the power needs to be on for this test. If you don't feel comfortable, call an experienced electrician.Start switch could be bad -- Set the VOM to RX1 and remove one of the leads to the switch. Clip the probes to the switch's terminals. The reading should be infinity. Press the start button and the reading should change to zero. If not, the start switch is bad. please rate these solution by saying how helpful or vote.
Dec 24, 2010 | Whirlpool Dryers
Model JVM1442-001 What is wattage??
Wattage is a term used to express magnitude of power. A common use is to define the electrical power consumption of your home appliances (check the labels). For example, look at the back label of your kitchen toaster. It might read 120 volts, 60 Hz, and 1200 Watts. The 1200 Watts is the power drawn by your toaster when you turn it on. You can get that (Watts) information for any appliance or device that runs on electricity in your house. That's important because that is the unit of measure the electric company uses to charge you in your electricity bill. The electric company bills your electric consumption in kilowatt-hour (KWH). All they are doing is calculating the watts by the thousands (that's the meaning of "kilo") for every hour you have your appliance turned on. The amount 22 cents per kilowatt-hour is close to how much the electricity is costing today. Back to your toaster, 1200 watts is equal to 1.2kilowatts. If you are using your toaster every day for an hour your monthly consumption is 1.2KWH times 30 days equals to 36KWH. That means at 22 cents per kilowatt-hour your toaster is costing you (36KWH times 22cents/KWH) $7.92 on that month. That's the toaster alone, now you can repeat this exercise for every appliance or device using electricity in your home. Start by just doing an inventory of each, do a log with four columns: (1)Name of the appliance, (2)Location, (3)Watts, and (4)Watts/1000 (to get the number in KW). Make a fifth (5) column and call it Hours. Make a sixth (6) column and call it KWH. Then sit down to estimate (think) for how many hours per month each device is turned on. Now multiply each value of column 4 by its corresponding hour number in column 5. Write the results in column 6. Add the results of column 6 and voila! You just have a pretty good estimate of the total KWH consumed in your home in 30 days. Multiply that by $0.22 (or get the actual cost per KWH from your electric service company) and see how close you are to the actual billing. Hope there is no surprises.
There are the science and engineering definitions of the term watt you can research to come to the same conclusion hereto, I just laid a practical perspective.
Dec 18, 2010 | GE Microwave Ovens
Why shuld we save electricity
The argument for 'saving electricity' is saving at 'peak' times so additional generators don't have to be started up to meet peak demand. The additional generators are smaller, they cost more to run per Kilowatt generated.
A second argument for saving electricity is so we can continue expanding our economy by adding new homes and businesses, without needing to build another electric generation plant.
A third argument for saving electricity is your bill is lower.
The Kvar product you posted under is a scam. If you want to reduce electric bill, consume less electricity.
http://www.nlcpr.com/Deceptions1.php
Oct 17, 2010 | Electric Eyeware Electric Saver Save...
Howshould iknow serfing charges in bsnl broadband
BSNL Broadband Dataone is offering ISP connection to home and business differently as the way and limit of usage are different. And for every plan the prices vary for single month or annual tariff. If pre-ordering for 1 year, the tariff is discounted to some amount.
Here are the various plans available for home subscribers who go for BSNL broadband home plans -
bsnl-broadband.jpgHome 125 plan
256 Kbps/Upto 2Mbps connection.
Monthly tariff is Rs 125 and Annual tariff is Rs 1250.
Download/Upload limit is 150 MB per month, and additional usage costs Rs 0.90 per MB.
There is no night unlimited browsing option available.
Home 250
Monthly tariff is Rs 250 and Annual tariff is Rs 2500.
Download/Upload limit is 1 GB per month, and additional usage costs Rs 0.90 per MB.
Home 500
Monthly tariff is Rs 500 and Annual tariff is Rs 5000.
Download/Upload limit is 2.5 GB per month, and additional usage costs Rs 0.80 per MB.
You can browse unlimited from 0200-0800 Hrs.
Home 1000
384 Kbps/Upto 2Mbps connection.
Monthly tariff is Rs 1000 and Annual tariff is Rs 10000.
Download/Upload limit is 5 GB per month, and additional usage costs Rs 0.80 per MB.
You have to give 1 month plan charges extra for security deposit.
Home 1800
512 Kbps/Upto 2Mbps connection.
Monthly tariff is Rs 1800 and Annual tariff is Rs 18000.
Download/Upload limit is 10 GB per month, and additional usage costs Rs 0.70 per MB.
Home 3300
2Mbps connection.
Monthly tariff is Rs 3300 and Annual tariff is Rs 33000.
Download/Upload limit is 5 GB per month, and additional usage costs Rs 0.70 per MB.
Sep 30, 2010 | YouTube Computers & Internet
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
How much energy dose a 7096 heater use
As far as I can tell, your unit is rated at 1600 watts max. That means it will use 1.6 kWh per hour. Check your electric bill for what they charge for a kilowatt hour but it is usually less than 20 cents. So I would guess less than 30 cents an hour at highest temperature. Hope this helps and please rate my answer if it was helpful.
Dec 30, 2009 | Lakewood Oil-Filled Electric Radiator...
Maytag MDE5000AYW huge expense to heat it!
Typical Dryer Heater wattage is around 5,000 watts or 5KW multiplied by the amount of time you run it. For instance 5000 watts for one hour is 5 Kilowatt hours multiplied by your electric rate. This gives you a cost for running it for one hour.
However, your heater runs more when the clothes are wet but less and less as they dry. A thermostat turns the heaters off around 160 Deg and back on at about 135 deg for normal heat. As your clothes get closer to dry the heater reaches 160 faster and 135 slower so that the on time is continually decreasing.
All this cycling translates to a heater on time of about 70% total I'd guess. Even if your vent line was blocked your heater on time would decrease due to safety systems turning the heater off to prevent fires.
All that being said you can approximately calculate electricity use as 5 KW multiplied by the amount of time you ran it and that number multiplied by 70% to account for heater off time. For a 5000 watt heating element that would be 3.5 KW multiplied by your electricity rate per KW. Adding a 5 amp motor that runs all the time would make the figure about 4.1 KW.
If you're still following me you need to keep track how many hours you dry clothes for the month and multiply the final number from above by that.
Let me point out the things that use a lot of electricity and you can hopefully pin down one or two you can affect. The things that use the most power have heating elements in them:
  1. Stove
  2. Dryer
  3. Electric Heating
  4. Air Conditioner
  5. Electric Water Heater
  6. Dishwasher with heated water and heated dry
  7. Refrigerators and freezers with self-defrost feature
Keep in mind that having company for a week or lots of family members will affect all the numbers. Your utility company usually offers a free (part of the rate structure) service that will help you track down high usage if you have an unusually large bill. Consider asking their assistance.
Sep 24, 2009 | Dryers
Calculate a bill
Hi you can Apply below mention formula
=ABS(SUM(COUNTIF(RANGE,"CATAGARI")-(COUNTIF(RANGE,"CATAGARI")))
RANGE = FROM WHICH CELL TO YOU WANT TO APPLY THIS FORMULA TO TILL WHICH CELL.
CATAGARI = WHAT DO U WANT < FOR FOR FIRST > FOR SECOND
May 22, 2008 | Excel (SS8SATAS5128400R)
14 people viewed this question
Top Cooler Master Office Equipment & Supplies Experts
k24674
Are you a Cooler Master Office Equipment and Supply Expert? Answer questions, earn points and help others
