Question about Intel Pentium III, 800MHz (229725001)
A disk read error occured
Unknown cpu ID, missing micro code A disk read error occured thats what i got everytime my PC boot pls help me..dunno what to do.. thanks a lot
    Sergeant:
  • 279 Answers
Your system BIOS no longer recognizes your processor. I'm going to assume you haven't replaced the processor recently, in which case it is a bios error. Can you enter the bios on startup, or does this occur before that? On most computers there will be a message saying something along the lines of "press F1 to enter setup" - of course, it could be F1, F2, F10, F11, F12, DEL or ESC... or possibly another key Try hitting all of those and see if it takes you to a BIOS menu. If you can't get to the BIOS, you're going to have to replace the motherboard. If you can get into the bios, you may be able to detect your processor from there. Without knowing specifically what bios you are using, or what motherboard so I could find the bios information, I can't say more. If you can get into the BIOS, it should tell you what version it is (usually on the top somewhere). Get me that information and we can go from there. If you can't get into the BIOS, it's time to replace your motherboard. Or, honestly, for a system of that age it might be cheaper to just buy a new (or used) computer to replace it.
Posted on Aug 28, 2007
SOURCE:
Hello when I try start my laptop I get a little blue box saying : selected boot image did not authenticate. Press enter to continue. When I do this it shuts itself down. I tried starting it in safe mode...
There are serious errors on you hdd and the system sees it as a hdd failure and consequetially it won't boot. Place your OS disc in the dvd drive, boot from it and choose repair.
Jul 28, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Any help with my problem?
Does the PC boot normally without it pluged in ? Have you tried it on another machine ?
Sep 29, 2013 | HP Computers & Internet
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
Everytime I switch on my Compaq Presario V3000, it displays Error 0200 Fixed Disk error. I will switch off and switch on the second time, then it will boot successfully. Pls advise how to resolve this...
hi,
Well, i think you have a corrupt windows problem. Try to boot with your windows xp cd in the drive. A screen should come up and you want to repair windows xp please read the following. repairing xp
Replacing the hard drive can be a second option and is not at all difficult, but then you have a brand new (empty) disk drive, and you have to reload all your software.
There are companies that specialize in recovering files from broken disk drives, but it is very, very expensive.
I apologize if it happened to you.
best regards,
Jazerblue
Aug 28, 2009 | HP Computers & Internet
Dell Dimension 9100 Blue Screen 0X00000024,00190293,86FA5B30,C000102,00000000. I tried to reinstall XP from CD and it says unable to locate Hard drive. Replaced Hard drive and tried again, same message....
Hope this help you...This is in relation to what your error code means, you'll need to check against the list.
  • Error 0x00000024 - This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
  • Error 0x00000004 - occurs because your computer processor detected and reported an unrecoverable hardware error to Windows
  • Error 0x0000007b - occurs if your computer is infected with a boot-sector virus.
  • Error 0x80004005 - occurs because the account that is being used to access the page does not have access to the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC registry key.
  • Error 0xc0000005 - occurs because of memory corruption.
  • Error 0xc0000034 - caused by a missing system file (usually Ntdll.dll in the %systemRoot%\system32 directory.
  • Error 0xc0000006 - occur if there is not enough free hard disk space on the NTFS-compressed hard disk partition when the SIS filter tries to read compressed back pointer data streams from the SIS volume.
Another common reason can be malware and spyware that penetrate to your computer registry and started destroying it... that's why it's so important you fix your registry right now!
trust this help.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Bios could not be loaded error code
Sure , you need to change the battery in your motherboard. Often it looks like a silver coin. What happens is that your bios setting are reset to default each time you restart PC, before updating bios (that is the solution from hp that you are trying), change the battery.
regards
Mar 04, 2008 | HP Compaq d530 CMT PC Desktop
Open Questions:
See all Intel Pentium III, 800MHz (229725001) Questions
Intel Pentium III, 800MHz (229725001) Logo
308 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
