Question about Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet
My proscan tablet is says google play stopped why!!!!!!!!!!!!
Cant install google play services
Hi if you're tablet is in good condition u should B able to get all you're google apps if u open up a Google account & connect to the internet .good luck
Jul 05, 2016 | Proscan PLT 9 TAB 9-Inch Tablet Black
How can I copy a document from the Proscan PLT7223G 7' tablet?
Check out "ES File Explorer File Manager" at Google Play Store. It may do what you are asking. See... https://play.google.com/store/apps/details?id=com.estrongs.android.pop
Jul 16, 2014 | Tablets & eReaders
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Proscan tablet support
Unfortunately, your tablet manufacturer maintains a "walled garden" of applications. That is, you can only install applications from a list of applications that they provide. Not all of the Android applications that are available through Google Play are available to this device.
The only way you'll be able to get around this limitation is to hack the tablet (if such a hack is available) to allow installation of either a full Android OS or other hack to allow Google Play. Doing this will void your warranty at least or could "brick" your tablet.
May 07, 2014 | Tablets & eReaders
How to fix my proscan will not run google it keeps crasing
Go into settings.
Apps. Select Google.
Clear cache.
If that doesn't work select uninstall updates. You will be questioned if you want to reinstall factory version. Select yes.
If that doesn't work back up and reset tablet.
Apr 21, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Google play support
Gary i have not been able to solve the problem either sorry
Apr 14, 2014 | Curtis ProScan 7" Capacitive Touch Screen...
Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Logo
35 people viewed this question
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
