Sansui LCD spare parts
I need a flat cable to connect the Ti-con board to the LCD panel. It's 35mm x 80mm having 35 felt conductors.
  • Suresh Chandra Kinnoo Jul 19, 2013
    I have to repair a Sansui 32" LCD TV. The Ti-con Board I bought came without the flat cable connection.
    The original cable got damaged while removing it & it is not available from the Sansui agent here.
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Http://www.alibaba.com/
Try this link.
Posted on Jul 18, 2013
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
Posted on Jun 18, 2008
  • 718 Answers
SOURCE: Is the T-Con board the LCD controller? What is
Website shopjimmy.com has Sony LCD Controller 400WSC4LV0.4 for the KDL-40S2000. Other sites may also have it.
Posted on Mar 06, 2009
SOURCE: Spare parts for Sansui TV
Where can I order the stand or base for the hdlcd 3200B TV?
Posted on Nov 04, 2009
SOURCE: definition of t-con board
Hello, I've got a Sony Bravia LCD TV. The top 1/3 of the screen looks fine, the bottom 2/3 looks blurry with some vertical lines. The screen does not appear to be broken. The screen is always like that, regardless of what is plugged in (RCA, VGA, etc.). What is the likely problem and how much can I expect to pay for this repair? Is this something we can do or we should take it to a shop? I could send a picture if that would help diagnose the problem. Thanks you.
Posted on Mar 03, 2010
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
My sansui sv21276 multi system has sound nbo picture screen is white
The t con board or the LCD panel is faulty. Can confirm by replacing the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 18, 2016 | Sansui Televison & Video
My sansui LCD wont come on. I have checked all the cables. I switched it off last night and it was fine
Sounds like the power supply regulator board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 10, 2015 | Sansui Televison & Video
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
Sanyo MODEL DP46848 Have this spot on front left of screen.Is this defect repairable. Any idea on how much to repair.Thanks
the cause it could be bad parts at the t-con board or has a loose connection going to the t-con board. before you come up with parts replacement you can re seat first the lvds cable going to the t-con board for the lcd panel. the t-con board is mounted underneath cover with metal shield.
Dec 04, 2012 | Televison & Video
Screen is blue (no Pic) but there is sound.
Double check the LVDS (cable from the main board to t-con) cable connection. Give if a wiggle to see if anything changes. Also check the ribbon cable (s) between the t-con and the LCD panel itself. It is possible that you may have a defective T-con board. Outside of checking the mentioned cables, you should get a professional diagnoses.
Nov 28, 2012 | Insignia 42" LCD Flat-Panel HDTV
How to replace sansui lcd screen
The LCD screen replacement is a skilled work. Almost all screens comes attached with its driver board, known as 'T'Con' board. You must have through knowledge in electronics to do this work, as any connections to T'Con board have change, it might damage both T'Con board as well as new panel too.
Jul 02, 2012 | Sansui HDLCD-3212 32 in. LCD TV
I am trying to find the logic/video board for my Sansui HDlcd3200a any Ideas?
I am an electronics tech so i know that finding spare parts for a tv can be very difficult. Your best bet is to try to purchase the board from Sansui. If Sansui cannot help you ebay is a great place to find spare parts.
Mar 03, 2011 | Sansui HDLCD3200 TV
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
Vertical lines across tv
Solid colr lines? It can be the T-CON board, connection between T-CON board and the LCD panel, failing LCD panel. I would try reseating the ribbon cables between the T-CON board and the LCD panel first, but be real careful since the ribbon cables and the connectors are very delicate!.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 23, 2010 | Olevia 227V TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
