Rca p50830bl manual - Televison & Video
    Champion:
  • 247 Answers
Type the rca p50830bl manual on search engine and download the manual
Posted on Jul 19, 2013
P50830bl convergence system failed why to fix
The model number suggests and older set and they rarely had convergence problems----take a look on the back not for model but chassis number; is it a PTK195?
Mar 17, 2012 | RCA Televison & Video
My RCA model P61929 picture is curved inward on the top and bottom
Is there also a misconvergence? If so you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!
hardrocko
Apr 27, 2010 | RCA P50830BL 50" Rear Projection...
Blue conversion unable to move left or right, only up and down
Must replaced the 2 convergence ICS and some or all it resistors.Must know how to solders?Buy a convergence kit at Tv repair World,Tvrepairkit.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 10, 2010 | RCA P50830BL 50" Rear Projection...
RCA 50" - Convergence problem and now "Popping" + no picture
The high pitch popping that you are hearing is arcing in the high voltage circuit. I would not suggest a repair on a set that is this old. Convergence repair plus a high voltage problem could run around $500-$600. But it is your call on the repair, I can only advise.
I hope this helps you.
asnowman
Sep 23, 2009 | RCA P50830BL 50" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL 50 in.
This is burn in on your set. Something that had those words set on your set for too long. There is no solution to this problem replacing the CRTs would not be cost effective...make sure you do not leave any still images on your tv for extended amounts of time.
Feb 04, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL will not turn on
You have a shorte chopper diode, on main board look in middle of BD. You will need to change Horizontal output and Block blue caps and big Diode.
Nov 26, 2007 | RCA P50830BL 50" Rear Projection...
Remote not working with P50830BL
Yes it certainly could be a problem with the remote sensor assy., as I have had bad ones from rca in the past, But mostly its been bad connections from board to board or a jumper or even a few times the Microprocessor IC was bad. The best and only way I know to trouble shoot this, without shotgunning part after part and may get lucky, is to scope out the data line comming out of the sensor while hitting a function on the remote. If theres no data comming out then check the b+ going to the sensor also. Trace the signal all the way to the processor. If signal does make it all the way there , then of course the processor is the problem. Now theres High voltage inside these sets, so its not advisable for a handi-persomn to fix this set themselfs. There really are no user serviceable parts inside these sets as they are all soldered in and you need speacial equipment to properly work on most if not all sets these days. I would say a fair repair cost for a problem like this I would estimate at from200 to 350 depending on the exact problem. Good Luck
Jun 27, 2006 | RCA P50830BL 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
