Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
I need a flat cable to connect Ti-con board to LCD panel for Sansui 32" LCD TV model STY0332. It is 35mm x 80mm & has 35 flat conductors.
Hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Posted on Dec 18, 2013
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: my sansui 19 in lcd tv is not receiving signal from my dell compu
check the cable,check the graphics adapter is seated in ur system perfectly,check if any boot sirens came from ur cpu when starting the system.
Posted on Jan 17, 2009
  • 15 Answers
SOURCE: PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Posted on Feb 23, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
I have sound butvideo is just multi coloured verticle lines
HI,
When you make any connections to the Lcd tv or led tv you have to make sure that all the devices are unplugged. if it would lead to major problems. they to check by using another hdmi port in you tv. Normally all tv has more than one hdmi port. also check the tv is it showing good picture while using cable box. If all the inpout it shows the the line then the t con board o the mother broad is faulty
Remove and reconnect all the connections on the t con broad. if the problem exist even after that you have to go for a new t con board . in some tvs the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 26, 2015 | Televison & Video
How to replace sansui lcd screen
The LCD screen replacement is a skilled work. Almost all screens comes attached with its driver board, known as 'T'Con' board. You must have through knowledge in electronics to do this work, as any connections to T'Con board have change, it might damage both T'Con board as well as new panel too.
Jul 02, 2012 | Sansui HDLCD-3212 32 in. LCD TV
My TV are blisting of left half display or black out of that. Hit or pressure on the back make sometimes full display well.
Hello
It is due to some loose fixation with its flat cables that connected to lcd disply screen to its T'con board. T'con [Timing Control] board is the driving board to LCD display. If there is some loose contact, the fault you describes here can occur. Just open the TV, and detach and reattach each flat cables that connects with T'Con board ot LCD screen. This must solve the probel of your TV. OK.
Nov 23, 2011 | Dynex DX-L42-10A 42 in. LCD TV
My tv screen is totally white audio is fine.
p { margin-bottom: 0.21cm; }
As you mentioned your tv have problem with the T con board. Normally in an lcd tv he t con board drives the millions pixels in the lcd panel in rows and columns. if any of the driver or a group of driver for rows and columns is fulty then the respected row or column will be missing in the picture.
This problem can occur under two circumstances fist is if there is any loose contact in the connections of the board. if so remove all the connection to the t con board and then reconnect it. There are total six connections in the t con board. Of which five will got the lcd panel and one will go to the mother board.if there is any loose contact removing and refining the connections will solve the problem. If not then you have to replace the T con boar.
Normally you can find the t con board in the bottom centre or top centre of the lcd Covers with metal cover or aluminium foil. I have added the picture of the t con board for your tv. I you need any more assistance feel free to contact me through fixya.
Ajin
Sep 19, 2011 | Samsung LN52B750 52 in. LCD TV
My 42 inch LG tv keeps going very dark on 1 side of screeen. Any solutions?
This problem is most likely caused by the T-CON board. It could be a bad connection of the cable from the LCD to the T-CON board. or the T-CON board could be bad. Sometimes you can disconnect and reconnect the flat cable(s) to the T-CON board and solve the problem. Else you can replace the T-CON board.
The T-CON board is the board that drives the picture to the LCD screen.
Mar 01, 2011 | LG Televison & Video
I have a Sony KDL40W4500 LCD TV which is only two years old and the TV has developed double/triple imaging, mainly on the right side of the screen. After about 15 minutes before I get a clear picture, but...
hi,
T-Con board failure or poor connection of flexible wire and LVDS cable. Sometimes these connection loosen up from their terminals. Try to unplug and reconnect these cables to refresh the connections. If the symptoms still persist you need to replace the T-Con board. T-Con board is installed on the upper side of your LCD TV and it has two flexible wire connected to LCD PANEL . stihl_070509.jpg
Jan 02, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
56 inch tv
The T Con board at the top of the back panel has 2 flat cables that connect from this board to the main board. Check these connection. Be careful. Lightly sqeeze in on the sides of the connector and pull. Push cables back in. Check picture. an you get any graphic from the tv on the blank side. If you can then definatly Main board is bad. Other wise replace the flat cable (FLDS cable) on side that is missing video. next replace the t conn then next replace the panel. I think the t conn board on this set is part of the LCD panel. It is Likely cheaper to replace the tv if the panel is bad.
Mar 25, 2010 | Samsung LN55A950 55 in. LCD TV
Feb 23, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
