Question about Sewing Machines
Bernina 708 sewing machine
How do I oil this machine? Does the top lift up/open?
  • Sewing Machines Master
  • 7,365 Answers
If you don't have a manual that tells about oiling, then contact bernina customer service and ask them if the sewing machine is self oiling or if you can oil it your self..
or here is a link for a manual, not sure if it will cover your
but it is free
http://www.bernina.com/getdoc/2f5d7505-d65a-42fd-b9a4-ef4e84046480/BERNINA_707_717_manual
Posted on Jul 18, 2013
  • 19 Answers
SOURCE: Bernina 930 where to put oil
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops.
Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
  • 6 Answers
SOURCE: Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Posted on Jan 17, 2009
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
Posted on Mar 23, 2009
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
  • 8 Answers
SOURCE: Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
Posted on Sep 06, 2009
Testimonial: "To swiss_tech Great help. Very much appreciated. Thank You"
I have been away from sewing for a while but have recently begun again. I have a Bernina 1010. The fabric feeder has quit working. Any trouble shooting tips? I no longer have my manual.
Hm, I'm more familiar with the Berninas older than the 1010. The old mechanicals will seize if they haven't been regularly oiled. Could be the feed dogs on your machine have seized for the same reason.
I've resurrected several seized Berninas from a 930 on down to some 530s by opening the top, side, and bottom and applying a couple drops of oil where metal rubs on metal. After the 830 Record, Bernina stopped including any extensive oiling directions in the owner's manual, even though the 930 requires it frequently. (Some say Bernina really wanted the repeat maintenance business, but the 930 also presented some special issues with the basting stitch and the electronic board.) However, I am uncertain how much a user can oil a 1010 without causing damage. Most Bernina manuals provide information for oiling the race but don't go beyond that. Something that may be worth trying is directing hot air from a handheld hairdryer into the area that houses the feed dogs to see if that loosens anything.
Whatever you do, don't use WD-40, 3-in-1, cooking oil, or anything other than fresh good quality sewing machine oil.
You can find a manual for the 1011 here. It may be close enough to your model to be of some use:
BERNINA Sewing Systems
There are some Yahoo groups whose specialty is the Bernina owner/lover, ie BerninaThirtySomethings, and some others. They are a very helpful and knowledgeable group that could be of assistance to you.
Oct 30, 2016 | Bernina Sewing Machines
How do I open top part of my sewing machine
all machines need some oil at some point in their lifetime . try contacting the manufacturer thru their website . https://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines
Jun 22, 2016 | Bernina Bernette 75
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
My bernina 707 minimatic..isn't working!! My needle keeps getting seized an won't move up an down...Then when i try to sew it sews blanks....
Replace the needle.
Make sure the needle is inserted the right way. If the needle is installed the wrong direction the machine will get stuck.
Check and correct tension of the bobbin. (Guide attached)
Start the top tension at four and adjust as needed.
When threading do it with the pressure foot up so any snags can be felt. If there are snags they must be corrected. While threading, little tugs of the thread along the way will help. The snags can be felt this way.
Aug 25, 2015 | Bernina Sewing Machines
My Bernina 830 sewing machine will not sew any of the decorative stitches.
Is this the vintage 830 record, or the new electronic model?
If it's the Record, flip the top open, and oil all metal-to-metal. Run for a full minute, oil again, and run another minute. It should start to work once the oil has been worked in.
Mar 05, 2015 | Bernina Sewing Machines
How to remove top cover on vintage bernina 830
You should be able to pull it off with your hands. It is attached by springs.
Oct 18, 2014 | Sewing Machines
How to open the lid of the Bernina 731
I looked at this manual - http://www.berninausa.com/webautor-data/486/BERNINA_730_731_732_manual.pdf and cannot determine how to do this without the aid of a flat edge screw driver.
Mar 25, 2010 | Bernina Sewing Machines
I have a bernina minimatic 807 (old), and am trying to change the bulb. It is really hard...got it out, in pieces, but it'd be really nice to take the door off...which I think I can if I can lift the top. ...
Oh my gosh--how simple it is:
https://www.youtube.com/watch?v=i4YuJS02jt0
However, perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjYqvrshIfRAhXj44MKHQ0TCEMQFgguMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja
While you have the machine open, it might be a good idea to apply a couple drops of good quality sewing machine oil or (better yet) liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. (Slowly turn the handwheel and watch the movement.) Also look for the oil port holes throughout the machine an apply a couple drops in each. Do NOT oil the plastic gears or belts!!! Also, move the stitch selector and feed dog levers and hit those with a little oil too. This will keep your machine happily humming!!! You'll probably notice how quietly it runs afterward!
Mar 11, 2010 | Bernina Bernette Deco 600
I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Sep 20, 2009 | Bernina Sewing Machines
I have an old Bernina 730. I want to oil it for use again, but the top (lid) won't lift although it has 2 hinges on back. Can't remember a latch being involved to open it. Can I just force the top open...
It's been a while since I worked on one of these but it is NEVER a good Idea to force something open unless you want it broken. I think there is a release inside the left side opening (where the light bulb is located). It should be towards the top.
sewman7
Nov 06, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
