Question about Nixon Lodown Watch
Buttons don't work after reassembling
My son jumped in a lake and somehow, water got into the watch. I took it apart to let it dry out. Got it to work again, but the buttons don't work. There is a seal still inside.. there are 2 small springs that fell out from I don't know where and 2 other springs that are soldered to the circuit board. Anyone know what I did wrong?
Hi, the buttons B & C are jammed on my Seiko 7T92 wrist watch. Is there a lubricant or substance I can use without effecting the watch to free these buttons?
With Seiko, the best thing is to send it to Seiko for service. They will clean it and replace all the gaskets on the buttons, and pressure test it.
If you want to try yourself. It is waterproof, yes? Soak for a couple of hours in warm soapy water. Lift out, dry, and try the buttons. If they are now free, spray with Jigaloo, which is a dry silicone spray and work into the buttons.
Dec 18, 2016 | Seiko Watches
My watch face has water droplets on the inside of the crystal face. what can I do?
I have a burberry watch and it has water droplets in it but its only the middle that's full of water dropplet
Oct 03, 2010 | Timex 27191 Wristwatch
I have water/condensation in the watch.
  • Decide whether the risk of possibly damaging the watch is worth attempting a do-it-yourself fix. If the watch is expensive, you may want to have a professional repair it rather than risk damaging the watch or invalidating the manufacturer's warranty.
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • Hope this helps!!
    Aug 21, 2010 | TechnoMarine TMAXS07 Watch for Women
    I have a Seamaster Omega Watch since last week have a fogging insde the watch
  • Aug 15, 2010 | Watches
    I have condensation on the inside of the glass on my watch. I have a pr50 automatic so i don't know if the normal jeweler will be able to fix it. It doesn't have a battery and was recomneded to me to send...
  • Aug 14, 2010 | Watches
    All buttons don't work can;t put watch ahead one hour none of the four function buttons want to work watch is 6 months old . I don;t have receipt..
    If you haven't got instructions, you can get them from the Timex web site "timex.com".
    At the bottom of the screen click on "manuals/downloads", then on "product
    manual download"
    Enter your watch type in the search box and click on "search"
    May 10, 2010 | Timex Expedition 40141 Wristwatch
    I was swimming in ocean. Somehow, stem opened and
    the hair dryer didnt do any damage but the water might have destroyed the movement, some ar inexpensive, get an est. to replace it. make sure u go to a good jewelry store.
    Oct 09, 2009 | Navy Seal Luminox Watch
    Start buttons don't work after battery change Adidas Sports Timer
    You will have to open your watch, because the contacts or contact springs are not stiff enough, so, you need to make them stiffer.
    Do as follows:
    1) Open your watch caseback
    2) Extract the movement (carefully and using tweezers), do not touch dial with fingers,
    3)Take small brush and lighter fluid (ZIPPO) and clean all pushbuttons in case from inside and out pushing them rapidly, then use dust blower to dry the fluid out,
    4)On the movement you will see contacts corresponding to each pushbutton on the case. Use needle or sharp metal pin to clean (scrape) off any visible residue from these contacts till they are shiny.
    5)Pull all contacts on movement sligtly outwards using tweezers but be careful not to brake. This will make them stiffer.
    6)Reassemble the watch and the problem should be sorted.
    Do not forget to rate, please.
    Aug 14, 2009 | Watches
    Timex Expedition Indiglo light no longer works?
    Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
    Jun 22, 2008 | Timex Expedition 40141 Wristwatch
    Casio Pathfinder 2273 Reassembly Help
    Hi there these small springs sit under battery connector tabs (Below)copper colors tabs so that theres enoughe spring pressure, for your watch to run. Hope this makes sense and remember its just a watch so dont stress out, lifes short and you never now when that meteors going to come in and vaporize us.
    Nov 18, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Nixon Lodown Watch Logo
    21 people viewed this question
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
