Question about HTC Vivid
HTC - Plantronics Blue Tooth Audio output mode
When I use the blue tooth headset to answer the incoming call, I will have to use the screen "Audio Output" button to manually switch the audio output from Vivid to my blue tooth device. The selection choices include "Speaker, Vivid, Blue Tooth device". How can I pick up the call using blue tooth hand free device (by pushing a button on the headset) and not having to manually switch the audio output on the phone itself ??
  • 19396 Answers
SOURCE: HTC Touch P3450 - Bluetooth issue
Set your car stereo to play input from bluetooth, which is make and model of your stereo?
Posted on Apr 18, 2008
  • 1223 Answers
SOURCE: my htc touch earpiece stopped working i can use
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if doesnt work then
speaker is faulty just get it replaced it happens sometimes do give me a feed back about it
Posted on Feb 23, 2009
  • 4 Answers
SOURCE: Unable to use Bluetooth on HTC Touch
Tab start then communication manager and tab bluetooth.Then tab x.go again connections-bleutooth and and make sure tha the bleutooth is turned on tick the device visible to other x.Then start and tab internet explorer . Your mobile start searching for a device.thats it.
Posted on Apr 04, 2009
  • 813 Answers
SOURCE: Without the manual for my BH M200 HTC blue tooth,
Try the default pair code as 0000, 00000, 00000000 or 12345. One of the above codes should work with your headset.
Posted on Sep 11, 2009
  • 14 Answers
SOURCE: can not find received blue-tooth file......
Hey there,
I had the same problem, you need to open the file explorer and then do as following:
Choose My device > My documents
Here you can see the transferred files via bluetooth.
Posted on Oct 04, 2009
How do you reset the device?
first you must put the blue tooth device in pairing mode,most blue tooth device manufactures use the power button for this ,by holding the power button down for 6 to 10 seconds when turning the device on it usually puts it into discovery mode,a solid light might stay on ,then you have to enter a pairing or pin code.Now most manufactures of blue tooth devices use a 4 digit factory pin pairing code they are asw follows 0000,.1234,9999,or 1111 i hope this helps
Feb 26, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
How can I conect to my HTC wildfire when searching my phone cant find my plantronics Many thanks
You have to put your blue tooth device into discovery mode,Most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds when turning the device on,then when you are searching they will pair ,now you will be asked for a pin or pairing code.Most blue tooth device manufactures use a factory pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 19, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I am having problems connecting my plantronics explorer 390 to my black berry curve
First turn your Blue Tooth setting to "ON" on your Black Berry Curve, as it searches for a Blue Tooth Device, Push and hold on the middle button of the Blue Tooth until you see a flashing "blue light & red light." It's important that you see both flashing lights.
May 19, 2010 | Plantronics Explorer 390 Bluetooth Headset
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do I register my blue tooth model 220
The passkey should be 0000 (four zeros) and you may want to review some new information we have now:
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Oct 10, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Open Questions:
See all HTC Vivid Questions
HTC Vivid Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
