Question about Home Security
Remote rubber push button cover ACSCTO Type 1
The rubber button cover in the tomb stone remote needs replacing, can I get the part off an old ACSCTO Type 1 Remote From an OVERHEAD DOOR CORPORATION 696 CD/B
  • 3197 Answers
SOURCE: My Craftsman 139.53879 remote won't learn the code
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Posted on Jun 29, 2009
  • 3197 Answers
SOURCE: How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Posted on Feb 02, 2010
  • 3197 Answers
SOURCE: Overhead light flashes and clicks
If the overhead light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on one of the sensors is not blinking ever so slightly or the light is dimmer than the opposite one. Check to make sure they are connected properly. The solid white wires go to terminal #2 and the wires with the black stripe go to terminal #3.
Posted on Aug 30, 2010
  • 3197 Answers
SOURCE: System is about three years
If it is the receiver and it sounds like it is they run about 2/3 the cost of a new unit. That is if you install it yourself.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote.
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Dec 21, 2010
  • 3197 Answers
SOURCE: About a week ago our
Press and hold for 3 seconds the lock button on your wall control. It is the one with a lock icon.
Posted on Dec 27, 2010
How to release the wires from all the tomb stone connectors on a 4 bulb T5 fixture in order to change the ballast?
If you are sure the ballast is gone, just cut the wire as close as possible to the ballast, throw the old ballast and buy a same wiring ballast, use wiring nuts to connect the wire from the new ballast to the wire from the tomb stone socket. DO NOT TRY TO take the wire out from tomb stone lampholder.
Below link is for your reference.
http://www.bulbspro.com/electrical/sockets/fluorescent-sockets.html
http://www.bulbspro.com/ballasts/ballasts/fluorescent-ballasts.html
Aug 28, 2013 | Computers & Internet
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
I have A COBY765 THE REMOTE STOP WORKING
Remote Controls don't go bad that easily. Liquid spills
or moisture under the rubber membranes will prevent
contacts being made whenever you push a button.
1. Try replacing new fresh batteries first.
2. Disassemble the Remote and clean both the board (PCB)
and the rubber membranes with a soft water/soap solution
3. Dry them and Re-assemble the unit
Jul 16, 2011 | Televison & Video
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from service@bhsciencetech.com
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 | Toys
My remote stopped working with my television. all I need is a manual that I cannot find. for CL007 remote
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Zenith ZN620 Remote Control
My apex digital converter's remote no longer works. Therefore I have no TV picture because the apex wants to be re-installed due to loss of electricity temporarily.
Mar 19, 2010 | Televison & Video
How do you use a new remote without a old remote to program it
press and hold 1 & 2 on the controller, and then it should connect and get a player number light.
if that doesn't do it, there is a button underneath the battery cover on the wiimote, and a corresponding button behind the face-cover of the wii console. Push the button on the console, and then push the button on the wiimote. That should do the trick also...
Jan 11, 2010 | Nintendo Wii Console
Keyless Remote Issue! Any darned car with a remote
get a thin slice of foam insulation and put it inside the remote with the old filmVitally
Sep 09, 2009 | 1999 Saturn SW
Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Dec 10, 2008 | JVC LT-26X575 26 in. LCD HDTV
Home Security Logo
112 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
