Question about Cameras
Broken polaroid z2300
Says there is no paper when there is, and makes a whirring noise when i attempt to print
  • 1 more comment
  • May B.
    May B. Aug 05, 2013
    I got the same problem. have you solve it already?
  • May B.
    May B. Aug 05, 2013
    i have got the same problem, have you solved it?
  • Shannen Paige Chandler
    Shannen Paige Chandler Aug 21, 2015
    No one has figured it out, looks like I'm taking mine to a camera shop, maybe that is the way
    New Friend:
I have the same problem no answers anywhere
Posted on Aug 12, 2015
Inkjet printer EPSON L 200 not booting up most times.Makes lots of Whirring noises, Scanner does not seem to initiate. After a lot of whirring and clicking all three lights come on. That's it.
Scanners tend to initiate simply by warming up their lamps and pushing the carriage back to its rest position
Whirring noises generally indicate either the ink pumps or the drive belts are faulty... which here might well mean the scanner drive belt is failing to return the scan heads to the correct position.
That would tend to indicate the belt or the drive motor have slipping teeth or there is a blockage, perhaps from bits of torn paper...
Aug 02, 2016 | Epson L200 All-in-One Inkjet Printer 27...
Brother HL 1440 won't print
Try first unplugging power, and removing toner
check inside for foreign objects or fragments of paper
Open all doors and close them back , and plug back power.
Sep 04, 2008 | Brother HL 1440 Laser Printer
Asus G750JW Won't Boot Properly, Monotonous on an off whirring noise near CD drive
Take the cd out of the drive. There may be a cd lodged in the drive.
Apr 04, 2014 | Computers & Internet
Printing tray is seem to not grabbing papers. when trying to print, it makes a lot of noise.
From your description there are two issues, the first is the papers in the tray are not been picked up, second! it is very noisy when attempting a print job. The gears are mostly plastic and have worn to the point that papers can no be scooped up, and finally the noise confirms ware and tare on the system. The cost to repair will be high! this is where a personal choice will need to be made weather to fix or replace, if you use it constantly then I would recommend a replacement.
Jan 12, 2011 | Dell 3000cn Laser Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
My pinter says paper jam I have have taken the back portion off and then looked thru the paper window with door open as best I can as best the wheels turn but when it start s to print I cam hear it...
The noise of the printer is not related with the software of your computer. If it says out of paper then you will try to clean the rollers of the printer. If it is still saying out of paper and have a weird noise then the printer is already defective.
Aug 14, 2008 | HP Office Equipment & Supplies
Paper feed malfunction
sounds like the item in the paper path that you can not see. or it has a faulty sheet feeder or some gears have failed in the printer
Sep 25, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Cameras Logo
134 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
