Question about Smeg Cooktops
How do i stop my induction cooktop from buzzing
My induction cooktop buzz's/hum's on any power setting. How do I stop it. I'm leed to believe it is the cookware vibrating on the glass top. Is there a cover I can put between the cookware and the glass top to absorb the vibration ?
  • 161 Answers
SOURCE: glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Posted on Jul 15, 2008
SOURCE: Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Posted on Sep 22, 2008
SOURCE: stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Posted on Jan 04, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
SOURCE: My prestige induction cooktop PIC
E3 means that the stove is getting overvoltage.
Plug it through a voltage stabilizer
Posted on Nov 02, 2011
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
Induction cooktop
Could be the child lock turned on
Jul 02, 2013 | Cooktops
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Cooktops Logo
Top Smeg Cooktops Experts
freddyfox
Timllfixit
ray gallant
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
