Question about Frigidaire Washing Machines
Frigidaire washer fafs4272lw0
Control panel doesn't allow selections
  • 5 Answers
SOURCE: Control Panel
did you ever get this fixed? I think it may have to do with the control panel or part #18 in the book which is part 134207700
please let me know....mine stays on HOT...but I finally unplugged it long enough and now I can only get COLD water. the part seems to have gone down on price so I think I will give it a try myself and hope for the best... tracyjos@hotmail.com
Posted on Nov 22, 2009
  • 6277 Answers
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
  • 6277 Answers
SOURCE: I have a Frigidaire Affinity
(no promises as I do not know your particular model but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
John C
Posted on Aug 10, 2011
richroth
  • 9472 Answers
SOURCE: Frigidaire stack washer dryer keeps filling with
Does the water enter the unit when it is in the off position?
Posted on May 23, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
    You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
    Posted on Jul 24, 2012
    I have a code of loc coming on and my dryer wont work how can I fix this issue??
    The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
    May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
    Loc error code on Frigidaire frontloader
    To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
    Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
    Frigidaire affinity washer
    Press any button wait 5 seconds then Press and Hold the Start button for 2 seconds
    Jul 01, 2017 | Washing Machines
    Fafs4272lw0 affinity washer
    Hello Brenda - I am more than happy to assist you! First, let's try resetting the washer machine. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit back on. Once the unit is operable, please select the Normal cycle and press one of the two selections. If the issue persists, then in the case the appliance may be experiencing a communication error with the control board, a potential wiring failure or a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
    Jul 18, 2013 | Frigidaire Washing Machines
    Ltf2140e
    Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
    Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
    How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
    Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
    Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire front loading washer drainage
    Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
    1) Verify a circuit breaker isn't tripped
    2) Advance the timer control dial slowly 360 degrees-
    If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
    If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
    Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
    3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
    4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
    Oct 01, 2012 | Frigidaire Washing Machines
    Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
    If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
    Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
    When i turn it on, it buzzes and doesn't start
    Sounds like the control board won't allow the motor to begin the cycle. Contact a professional for an accurate diagnosis.
    Sep 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
    HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
    This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
    A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
    If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
    I hope this helps.
    (the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
    Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
    Washing Machines Logo
    32 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
