Question about Westinghouse Refrigerators
Why is the plastic runner on the vegetable crisper so weak?
Bought a Westinghouse Upside-Down Refrigerator some time ago,but shortly after,the plastic glider on the the vege.crisper snapped.Supa-glued it back on,but in a short time it broke again.Is there any way to fix this problem for good?Maybe if the crisper/keeper was made all in one piece,instead of a separate piece of plastic that is glued together to form the glider,it would be more efficient!The Model Number is BJ434.Would appreciate any feedback!Thank you!Layla Ostenfeld.
    Top Expert:
  • Westinghouse Master
  • 12,650 Answers
Replacement is the option and the drawer is one piece not a glued guide== the wear and tear actually cut the plastic lip off
Posted on Jun 06, 2017
aborcass
  • 2651 Answers
SOURCE: Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Posted on Feb 27, 2008
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
smuschanow
  • 20 Answers
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you. I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Posted on Nov 25, 2009
woodchuck789
  • 4066 Answers
SOURCE: vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Dec 17, 2009
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
The lettuce freezes even when we dial the control to 45 degrees. Please help
#1 Does your lettuce freeze in the crisper drawer? If so this would be your thermistor located behind the temperature control knob. At the very top inside the top cover is where it is located. It looks like a device with a wire covered in plastic that reads your temperature and allows your refrigerator to cool evenly. If your lettuce is not in the crisper drawer than this can also freeze your vegetables and dry them out. I hope I helped you.
Sep 02, 2010 | Maytag MZD2766GES Side by Side...
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Fridge - Westinghouse siloueete frost free 415 problem
Temperature sensing thermostat could be going bad. Also check to make sure the refrigerator light is shutting off when you close the door. There should be a switch to control the light operation when the door is opened and closed. Operate the switch by pushing it in as if the door was closed and make sure the light goes off each time.
May 18, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
