Question about Frigidaire Washing Machines
Fafs4272lw0 affinity washer
Normal cycle doesn't allow selection of temperature, soil level or spin speed
  • Official Brand Answer
  • 4,342 Answers
Hello Brenda - I am more than happy to assist you! First, let's try resetting the washer machine. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit back on. Once the unit is operable, please select the Normal cycle and press one of the two selections. If the issue persists, then in the case the appliance may be experiencing a communication error with the control board, a potential wiring failure or a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Posted on Jul 18, 2013
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Frigidaire Affinity LAFW8000L will not
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 06, 2011
How do i reset a front load washer?
Well you did not list the model so for me to return mine to factory setting I have to press and hold these two buttons at the same time ( spin speed, soil level) until I hear a signal sounds a few seconds or so. the other is (cancel and pause.) or cancel and any cycle.
May 01, 2016 | Frigidaire Washing Machines
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
Jan 13, 2014 | Frigidaire Washing Machines
Frigidaire affinity washer
Press any button wait 5 seconds then Press and Hold the Start button for 2 seconds
Jul 01, 2017 | Washing Machines
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
Doesn't sound like it's working
Could you please describe the problem you are having a little better please?
Nov 27, 2012 | Hotpoint HSWP1000MWW 27" Top-Load Washer...
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
How to I reset my Affinity to factory settings? I know you hold down to buttions for a few seconds but I forgot which buttons they were.
Hello, Thank You for using FixYa. I will be helping you today.
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity washer program error. When you turn the knob to normal washing, it only has 26min when it use to have 40min and now you can't make any choose any options. The options are all out...
factory reset you have to
until you hear a beep. This is no more than 10 seconds.
If this helps PLEASE RATE ME >.....
Jun 25, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
