Remote rubber push button cover ACSCTO Type 1
YOU PEOPLE ARE DUMB AS A STUMP
Posted on Jul 24, 2013
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
Where is riccar radiance filter reset button
Remove the bag door, you will see a little round rubber piece about 1/4 in diameter on the motor cover. Remove the rubber piece and very gently push the button while the brush roll motor is running
May 15, 2014 | Riccar Vacuums
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
Nov 04, 2012 | Genie Company Home Security
I have A COBY765 THE REMOTE STOP WORKING
Remote Controls don't go bad that easily. Liquid spills
or moisture under the rubber membranes will prevent
contacts being made whenever you push a button.
1. Try replacing new fresh batteries first.
2. Disassemble the Remote and clean both the board (PCB)
and the rubber membranes with a soft water/soap solution
3. Dry them and Re-assemble the unit
Jul 16, 2011 | Televison & Video
How to play 2 player plz help .we pluged in both keyboards but thy pic up as one.thanx
Here's how:
1. Remove the second Wii Remote's battery cover and insert two AA batteries into the device.
2. Open the SD Card Slot cover on the front of the Wii console. Push and release the console's "SYNC" button.
3. Push and release the "SYNC" button below the Wii Remote's batteries.
4. Wait for the Wii Remote LED to stop blinking.
5. Replace the Wii Remote battery cover.
6. Snap the Wii Remote into the back of the second Logitech Wireless Guitar Controller for Wii. Your second guitar will then use your Wii Remote's power and synchronization to the console and respond to Guitar Hero.
Hope this helps!
Mace
Dec 25, 2010 | Activision Guitar Hero III: Legends of...
MY REMOTE CONTROL IS STARTING TO HAVE SELECTION PROBLEMS. THE VOLUMN BUTTON IS STICKING. WHERE CAN I GET A NEW REMOTE?
Hello
Just try to clean it first. Open it without breaking its cover. There may ba a screw inside the battery compartment. It is lock fitted atits side, and pushing with a scredriver or such tool, you can **** it open. Inside you can see a circuit board with some components. Don't disturb them. Just clean the printed ciruitboars, face that comes in contact with the rubber push pad, with some mild solvents like rectified sprit, or medical quality turpentine. Never use petrol or such vigorous solvents for this, as they will harm the rubber parts. Clean the rubber pads' inside and outside with a tooth brush dipped in the above said solvents. Refit it only after dried well. this must help you.
If not go for a new one of same type and number. You can find it in most of the electronic sparepart shops. OK.
Dec 16, 2010 | Emerson Televison & Video
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote stopped working with my television. all I need is a manual that I cannot find. for CL007 remote
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Zenith ZN620 Remote Control
How do you use a new remote without a old remote to program it
press and hold 1 & 2 on the controller, and then it should connect and get a player number light.
if that doesn't do it, there is a button underneath the battery cover on the wiimote, and a corresponding button behind the face-cover of the wii console. Push the button on the console, and then push the button on the wiimote. That should do the trick also...
Jan 11, 2010 | Nintendo Wii Console
Remote problem
Look carefully at the buttons and see if one of the rubber buttons is slightly pressed in, ever so slightly!!! look ever so carefully to see of the OUTER rim of the rubber button is off the plastic rim of the R\C [ remote control] usually PUSHED IN at the RIM ot the rubber button. That causes a short and confuses the r.c in two diferent directions.
Jan 29, 2008 | Toshiba W522 VHS VCR
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
