Question about Stryker 1088 Camera W/ X-7000 Light Source O/R Camera
Stryker X700 problem of auto changing in colour while use
The color and light is automatically change while x7000 use in case. this making problem on doing case
Stryker x7000 light source. power Fault,i have checked Power Supply component main capacitor fuse and bridge rectifier all is OK but no display and out put,kindly help me please.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 01, 2015 | Televison & Video
What type of fluid do i use in my transfer case
If you have the manual transfer case (lever actuated), use DEXRON-III Automatic Transmission Fluid. If you have an automatic transfer case (push button actuated), you should use the fluid that GM recommends. Some owners' manuals may say to use Automatic Transfer Case Fluid (GM Part No. 12378396), which is a reddish colored fluid. GM has a new Auto Trak II Transfer Case Fluid (GM Part No. 12378508), which has a bluish color to it. The newer fluid has better friction modifiers. While your doing the job, it's a good idea to change the drain and fill plugs (GM Part No. 15032997) out too.
Nov 19, 2012 | 1998 Chevrolet K1500
How to make folder in dos command how to rename the folder in dos command how to change the font color of the dos command
To make a folder type: mkdir FOLDER_NAME Where FOLDER_NAME is the name that you want to give your folder.
To rename a folder type: rename FOLDER_OLDNAME FOLDER_NEWNAME Where FOLDER_OLDNAME is the old name of the folder and FOLDER_NEWNAME is the new name of the folder.
To change your font colour, use the color command by typing: color XY Where X is a hex value representing the colour of the background of your window and Y is the colour of your.
The values that you can use for X and Y are:
0-black
1-blue
2-green
3-aqua
4-red
5-purple
6-yellow
7-white
8-grey
9-light blue
a-light green
blight aqua
c-light red
d-light purple
e-light yellow
f-bright white
Mar 25, 2011 | Computers & Internet
My printer is not printing in color. I just replace all printer cartriges
Check the printer properties to make sure printing in color is enabled. Sometimes automatic will not print in color right away.
Mar 01, 2011 | HP DeskJet 940c InkJet Printer
Default Setting Change?
you need to set you initial copy screen up as auto colour select then go into copy settings and store them like that.
Jun 02, 2009 | Office Equipment & Supplies
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
Display screen going whitish in colour
Change the mother boardof the cell phone
Jul 11, 2007 | Samsung SGH-X700 Cellular Phone
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Stryker 1088 Camera W/ X-7000 Light Source O/R Camera Logo
35 people viewed this question
Top Stryker Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
