Question about Gestetner Office Equipment & Supplies
Gestetner 1302f and dsm415pf form overlays
Need to create a electronic form overlay that will work for the above printers. I jcan create a standard overlay, but apprently these printers require a .rpo extension instead of the standard .ovl.
Paper jam dsm415 copier help
Posted on Dec 10, 2008
I need driver for scanner and printer for ricoh nashuatec multifunction dsm415pf mashine for free
Hello!
You can use the scan-to-email or download the twain driver.
For that you can go to www.ricoh-support.com and download it.
See you!
Jul 05, 2011 | Gestetner DSm415pf Digital Imaging Sytem
What is the correct driver for using a Gestetner Super 3G DSm415pf with a MacBook OS 10.5.8?
You need the Postscript driver.
But the question is: The machine already have the PS optional?
Because you will need it to use that driver. For that model it is optional.
Mac OS do not support the standard PCL driver
May 02, 2011 | Gestetner DSm415pf Digital Imaging Sytem
All lights blinking Deskjet F2180
Welcome to FixYa!
I assume that the "Start Copy Black" light and "Start Copy Color" light is also blinking.
The product has a fatal error or the scanner bar is unable to move.
Reset the printer:
  1. With the power on, disconnect the power cord from the rear of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the rear of the product.
  4. Press the Power button to turn on the product.
  5. Wait until the Power light stops blinking. The reset is then complete.
Solution two: Make sure that the control panel overlay is installed correctly If the control panel overlay, or bezel, is incorrectly installed, the product might indicate a false error condition. If the product has not been set up before, ensure correct installation of the control panel overlay. NOTE:
If you already installed the control panel overlay, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 31, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
How can I scan and store in a pc from gestetner NRG-DSM415pf
First of all you need to create a folder on the PC.
Then create users and specify the path for that folder.
To create user download the user manual. Is there everything you may need.
Mar 26, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I have a printer model dsm415pf I need drivers and manual for the printer
This gestetner is the same as the Ricoh aficio 1515 .You can get the drivers and manuals at www.ricoh-support.com
Jan 04, 2011 | Gestetner DSm415pf Digital Imaging Sytem
Hi, I need some help here. My Aunt uses a Pronto M17 sure step with a Invacare controller that has Mk6ispj and W/pss written on it. The unit works fine but wont turn off and has trouble turning on as well....
The Mk6 spj w/pss has an overlay with buttons over the sensors. The functionality is very much like a microwave keypad. These buttons go bad over time and you can replace the overlay for under $20. When you press the buttons they contact some inductive sensors on a circuit board underneath which induces a current flow in the sensor. The pads flatten out over time and dirt, oil and food can accumulate under the pads between the pad and sensor. This causes decreased sensitivity and poor function of the buttons. You may be able to carefully remove the overlay and clean it and the underlying circuit board with spray electronic cleaner. This works for awhile, but I usually just replace the overlay. The new overlay comes with a new layer of adhesive. Hope this helps.
Dec 24, 2010 | Invacare Supply Group Pronto M61 Standard...
I want to print metallic gold and gold-foil TITLES on a standard CMYK background with an Alps 5000P. What is the procedure to overlay the spot color where I want to print the gold?
Create a mask or layer for each spot color you want to print using only black. When printing spot colors anything on the mask in black will be printed in the spot color. For foils, print a couple of layers of black ink before you print the foil to get a very good effect. Remember to check the overlay option so the paper doesn't get ejected.
Nov 11, 2010 | Alps MD 5000 Thermal Printer
When printing in book fold on my new acer laptop each half of the page is printing on a separate sheet although i have printed in this form once before.
this problem was not resolved as my problem did not relate to a gestetner machine but a Lexmark printer. At no time did I declare what machine I was using, and can only assume that the mix up occured when I was re connected after my first connection had ended prematurely.
Jan 17, 2010 | Gestetner DSm415pf Digital Imaging Sytem
163 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
