Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Blow back though oil dip stick - Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
2 Suggested Answers
mattofilms
  • 110 Answers
SOURCE: Blowing oil out of dip stick
sounds like the rings are shot. I'm guessing the best thing for you to do right now is head to autodrone and borrow a compression tester and have it tested.
Posted on Jul 05, 2009
How much oil do I put in my car 19 00 cc
1. Turn off engine ,
2. Take of oil cap on engine
3. Put in a little oil in oil filler hole of engine.
4. then pull out the oil dip stick from engine
5. and clean the dip stick on a rag.
6. Put dip stick back in engine
7. pull out again and check the level showing on the dip Stick
8. If level is too low on dip stick and is not at full level go back to step 1
These steps ensures you avoid over filling the engine with oil
Tip for beginners
The 4 litre oil bottle is way too much oil for an engine to handle.
If you have a full 4 litre oil plastic bottle square shape . hold the bottle on its side to pour the oil out slowly and smoothly.
Jun 04, 2016 | 2005 Mitsubishi Carisma 1.6
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
How do you take the Dip Stick off
the dip stick twists out, and sometimes are tight, or hard to turn. be sure and replace it as tight as you can, back presure in the crankcase will blow it out if it's not tight
Jul 13, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
Why is my diesel blowing oil from the dip stick?
Sounds like blow-by...due to worn piston rings. (Compression that gets pushed past the rings, into the engine crankcase, and out the dip stick tube.) Make sure that a vent may not be plugged.
Sep 08, 2011 | Isuzu Trooper Cars & Trucks
Can't find where to add transmission fluid in a 2006 all wheel drive equinox
I am unfamiliar with exact car, however, It is not unusual for transmission oil to be put in via the the transmission dip stick tube - do not confuse it with the engine oil dip stick tube. Do it slowly and make sure you dont over fill or you will eventutally blow your transmission box seals or worse. Let the oil settle before checking levels too because it is easy to misread the dip stick when you have used the dip stick tube to fill oil in.
Jun 04, 2011 | Chevrolet Equinox Cars & Trucks
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
Replace alternator in chrysler town and country minivan
REMOVAL
  1. Release hood latch and open hood.
  2. Disconnect battery negative cable.
  3. Disconnect the push-in field wire connector from back of generator.
  4. Remove nut holding B+ wire terminal to back of generator.
  5. Separate B+ terminal from generator.
  6. Raise vehicle and support.
  7. Remove the right front lower splash shield.
  8. Remove accessory drive belt, refer to the Cooling System for proper procedures.
  1. Remove the lower oil dip stick tube bolt (Fig. 2).
  2. Remove wiring harness from the oil dip stick tube
  3. Remove the 3 mounting bolts.
  4. Lower vehicle.
  5. Remove oil dip stick tube from vehicle.
  1. Roll and remove the generator from vehicle (Fig. 3).
INSTALLATION
  1. Roll and place generator in position on vehicle (Fig. 3).
  2. Install upper bolts to hold generator in place.
  3. Lubricate the O-ring. Install oil dip stick tube.
  4. Install the upper oil dip stick tube bolt.
  5. Place B+ terminal in position on generator.
  6. Install nut to hold B+ wire terminal to back of generator.
  7. Connect the push-in field wire connector into back of generator.
  8. Raise vehicle and support.
  9. Install the lower mounting bolt and tighten.
  10. Install the lower oil dip stick tube bolt and tighten (Fig. 2).
  11. Install accessory drive belt, refer to the Cooling System for proper procedures.
  12. Install the right front lower splash shield.
  13. Lower vehicle.
  14. Install wiring harness to the oil dip stick tube
  15. Connect battery negative cable.
  16. Verify generator output rate.
Dec 13, 2010 | 2001 Chrysler Town & Country
1979 chevy 350 modded to 383 stroker i have been
Sounds like the engine can't breath,
make sure pcv valve is good,or oil cap is vented.
your engine is building up pressure and has no where to vent,so it blows the easiest thing,the dip stick
Nov 18, 2009 | 1983 Chevrolet K1500
I can't locate the transmission fluid dip stick for 2003 Grandam
Your transmission is sealed and has no dip stick, checking the fluid level properly involves using a factory scan tool.
Apr 26, 2009 | 2002 Pontiac Grand Am
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
16 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
