Question about Electronics - Others
Contaess transcend pen drive
I have Purchased USB Pendrive 3months back nowit is not working showing like not recognizing.i want to know the repair address
    Champion:
  • 221 Answers
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Posted on Dec 25, 2013
SOURCE: Transcend USB not detected by Win Xp
well kaushal, it seems that the windows utility programs on ur pendrive has been corrupted thats why u r nt ablr to use it on any pc....
in this case u can do only one thing, try to connect ur pendrive in a pc running on a LINUX based PC.
coz LINUX does'nt require the windows utility programes... this is the only way out.
i hv also done it in past
Posted on Nov 07, 2008
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Posted on Jun 21, 2009
SOURCE: pen drive is not working properly
Hai vanakkam, Pls insert ur Flash, it it s detected, u wil go to mycomputer-->rightclk-->manage--->storage(In left side pane)--> disk management--->rightclk on ur media--->change drive letter and format. If uhav RAW file system defenetly u wil get ur pendrive. nandri vanakkam.
-Thanga.Rajakumaran-Chettikulam-nellai-
Posted on Sep 03, 2009
Geekman
  • 32281 Answers
SOURCE: Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 05, 2009
  • 23 Answers
SOURCE: i cannot format my 64 gb TRANSCEND pendrive
use the mfomat utility software and fornat the pen drive it wil shorly solve u r problem 100%.............
Posted on Oct 06, 2009
Usb disk not recognized
Check on other PC to see if it will recognize the USB drive. If not recognize the drive is most likely damaged beyond recovery.
May 20, 2014 | Super Talent 128GB USB 2.0 Pendrive Silver...
How to Repair my 4 GB Malfunctioning USB Pendrive ? Windows is not recognizing it .. :\
try it on another machine....else u need to download an application called KILLDISK (windows version) from google and use that to kill the USB pendrive...then format it...
warning...this operation will wipe ur pendrive.,..so be ready to loose all data in that....
pls revert back and kindly leave a feedback and rating for this solution....it will help me become a "Guru" here...from Master...
regards...
Sep 29, 2010 | Transcend (589307) Media
My USB is not being recognized. I am
my pendrive is not been recognised and the pendrive is in full working order on other pc any solutions?
thank you
May 02, 2009 | TwinMOS Technologies 256MB Twinmos 802.11b...
Recognized my 4gb transcend pendrive
Try windows repair, it should fix the problem.Else connect the pendrive and check the port settings.You can check for the port settings by
right click on "my computer"-->properties-->hardware-->device manager
A new window opens and at the bottom probably you'll find "Universal Serial Bus controller". Expand that option and check whether all the ports are enabled.If the pendrive is still not detected, then the problem is with the port.Check the same with the other available ports.Any further doubts add comments.Would be glad to answer.Good luck.
Jan 21, 2009 | Transcend (589307) Media
I have windows XP svpk3 OS,when i insert my 1GB moserbaer pendrive its not detected,windows showing error USB device not recognige,in divice mannager its showing UNKNOWN DEVICE whats the solution for...
Most likely the pendrive is no longer working. The simplest way to check that, is to try it in another computer and see if it's recognized. If this is the case then the USB ports on your computer are not working which I doubt.
If it is seen as unknown device that means that the electronics in the flash drive got bad and it is unrecoverable.
Jan 18, 2009 | ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD)...
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive is not working
I agree with geokohler...
removing the original software on the device many times allows said device to be used on any computer, obviously once the software is removed the devicxe will need to be reformatted!
Jul 13, 2008 | Transcend (589307) Media
Pendrive related problem
u need to check the working of pendrive on some other system/pc. may be ur pc needs usb configuraton?
Apr 13, 2008 | Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
