Question about Mastercool Heating & Cooling
Putting in a mcp44 water distribution hose assy for a mastercool
Not how the run off hose that goes through the drain off from the mcp44 water distribution hose assy
3 Suggested Answers
SOURCE: Have Mastercool. 1/3 of media is not getting water.
After looking at an exploded view in an operators manual, I found on another site and reading the "how to replace" media section, no mention was made of anything that fastens the water jacket assembly to the media. The problem was calcification, due to Arizona's hard water that had literally superglued the water jacket to the media. Using a flat bar and some gentle persuassion, I was finally able to lift one side end of the water jacket and slowly work my way to the other side. As I suspected, the PVC water tube was almost totally clogged with calcified debri that had been sucked up by the water pump. As a preventative for this in the future, I fashioned a filter bag from a piece of nylon window screen and placed that under and around the pump section and tied it off just below the motor assembly. Hope this helps someone else. ts
Posted on Jun 25, 2009
  • 4 Answers
SOURCE: how do i drain a mastercool of water manualy?
Remove drain pipe from water pan. You can usually turn it counter clockwise. When drained, clean with fresh water and replace pipe buy placing pipe dope or teflon tape to avoid leaking.
Posted on May 10, 2010
How to drain lg front loader with an OE error. I want to check the filter but there is water in the drum
Take cap off black hose and drain into shallow pan till no water comes out then remove filter And make sure to wipe filter seal clean and pump assy where it goes back in for proper seal. If nothing's in the filter then it's your pump and that's a common occurrence on the LG front loads however replacing the pump is better left to a professional.
Jun 10, 2017 | LG Washing Machines
Water running out of the tub through the drain hose
The drain hose is either sitting in water with no air gap or the hose is not going up high enough...either way it is causing the water to siphon out of your machine...
The hose should go up higher then the highest water level and have an air gap where it goes into the drain pipe or it will not work..
heatman101
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
My whirlpool washer never fills with water. It goes directly to the drain.
Make sure the end of the drain hose is higher than the expected water level in the tub--otherwise it just runs through. Extend the drain pipe up to the hose end height and tie the hose to the pipe so that the rushing water from the pump doesn't force the end out of the drain.
Aug 25, 2009 | Washing Machines
Water runs out of the bottom of the washer as rinse water runs in. Washer if top loading Whilrpool. Model #WTW5840SWO
Check the pump assembly ( this is a common pump ) first for a leaking problem, check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tips: This pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
May 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water collects in front of the machine on the floor
leaks
Check the pump assembly ( this is a common pump ) first for a leaking problem, (changing a common Frigidaire pump tips ) check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tipsThis pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
Apr 03, 2009 | LG WM0642H Front Load
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
F02 error on Kenmore front load, followed solution, problem still exist, What next?
cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't spin or drain water
you checke dthe drain??? how??? i would assume that you have something stuck within your drain pump assy( bra underwire-- money--- toothpick--nail/screw) VERY common issue, youll need to remove the front cover and remove the hose leading to the pump to look inside. DISCONNECT POWER-- PUMP IS ALWAYS LIVE!!!!!!!!!!!, oh yea and youl need a bag to collect the water when you disconnect the hose, YOURE GONNA GET WET!!
Oct 19, 2008 | Frigidaire FTF530FS Front Load Washer
Washer won't fill
??????? sounds like perhaps you got your 2 hoses reversed when changing the pump assy
Apr 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is not draining
yea popping off the front cover to access the pump assy release the hoses leading to the pump and remove the debris clogging the pump assy
Mar 17, 2008 | Maytag Neptune Washer
Heating & Cooling Logo
189 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
