Back to:
Tags:
IBM 4039 Model 16L Laser Printer
Missing characters, missing print barcode lines
posted by allflex on Aug 28, 2007
My IBM 4039 10R laser printer was working perfectly last week, but it start to print funny symbols and missing characters after I installed a Samsung scx 4521F laser printer a few days ago. I have tried to re-install the driver and reset factory defaults, didn?t help. My computer is fine, I tried it on the other printer, the printing is fine. Please help.
Comment by allflex, posted on Aug 28, 2007
Hi Printerguy
Thanks for the help, I don't use any network cards, both printers are local printers, two printers are not connected through any networks. I use them individually.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
Printerguy
Rank:Wiz Wiz
Rating: 89%, 68 votes
Hi, It's been a while since I worked on these, so I'll go out on a limb (as far as my rating goes) and say that the few times I've seen that happen usually results from a bad network card. Now you may not be using a network card, so if your not then I'm not really sure what would cause that to happen on the printer side. The environments that I've seen that happen in are with an AS400 and the network card just gave out. You most likely tried this, but you might want to make sure that the computer isn't using one driver for both printers. Good luck.
Rating Locked! (?) allflex has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on missing characters, missing print barcode lines:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
mp520
I have a Unisys AP9310 laser printer which is the same as...
Printer worked fine for five year and started getting 27...
Suddenly my 4039 will not print envelops. When I manually...
print quality is bad
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
