Question about HP DeskJet F380 All-In-One Printer
Printer not printing
My printer (types) like it is printing but no ink shows up. One time it didn't print anything but the footnote on the page. I tried cleaning the clear belt thing in the back but that didn't help. Any more suggestions? Thank you very much.
  • 3 more comments
  • Anonymous Feb 22, 2008
    I cant believe, even I'm experiencing the same problem with my deskjet! Mine printed nothing but a dot on the entire 2 pages and after that, its not even initializing! All documents keep going into the queue but no printing .... I really wish I'd never bought a HP!!
  • Sonofprint Apr 22, 2008
    The printer machinates, but no ink appears after this work is completed? I've been to approximately 95 kilograms of websites and troubleshooters, but the dang thing prints nothing. I have not replaced any print cartridges since I bought it. I used it only a veryt little: for some copying and one print job - all a while back, but never since.
    Shouldn't products work?
  • tocountryto Jun 15, 2008
    Orange light keeps flashing and printer will not print anything but unintelligable print. This happened following a paper jam. I have tried shutting the printer down and trying to correct by hitting the orange button but that only serves to make the green button flash and still doesn't print anything but symbols.
  • Anonymous Jun 16, 2008
    My black cartridge stopped printing so I decided to change it. However the new cartridge doesn't print anything either. The ink level indication shows that it's full, so presumably it's inserted properly. The printer prints fine in colour.
  • Anonymous Oct 11, 2008
    my printer copies great but prints very small off computer
    Sergeant:
  • 279 Answers
It sounds like it is out of ink. If you have replaced the ink cartridge recently, is it possible you forgot to remove the small piece of tape that is placed over the head to prevent ink leaks? That has to be removed before installation.
Posted on Aug 28, 2007
You are using the wrong driver. Check and make sure your printer is configured as "HP F380" and not anything else. The computer is sending commands to printer telling it to print a "dot" instead of the page intended.
Posted on Apr 21, 2008
  • 4 Answers
My printer is printing eveything small, what can i do?
i have a HP psc 1210.
Posted on Jul 23, 2009
    Novelist:
  • 119 Answers
Try also checking this. check and see at the bottom of the cartridge whether it has dried ink. if so it will not print because the dried ink is blocking the way. use a cotton cloth and try to wet and wipe out the dried ink. might work......
Posted on Jun 13, 2008
My printer prints very small
Posted on Oct 22, 2008
No Mr Guru, its got nothing to do with the tapes on newly replaced cartridges, my printer is so new that my free cartridges are still good to use ..... but what can be done when the printer refuses to print even though its turned on and online ...... My printer is just lying catching cobwebs the in the next room .... even the HP Helpline in Singapore dont respond ....
Nest time I'll make sure I buy a better brand and model!
Posted on Apr 06, 2008
SOURCE:
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
I have an HP Deskjet F380 All in one Printer/Scanner/copier which is about 6months old-it has always performed perfectly but at present I`m having trouble printing photos from computer.The quality of print...
hey payne
here is a copy of your problem.
Issue The printer is working, but colors in the printed output are missing, faded, or dull in comparison to the original. Solution Step one: Check the paper Verify that the paper type is appropriate for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface. Step two: Check the print settings
  1. In the software application you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Verify that your printer is selected and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. In the What do you want to do? menu, select a task. The What do you want to do? menu lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • Print quality: If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size: Make sure this matches your paper.
    Additional options: click the Basics tab, then click Advanced Features . The Advanced Features window opens.
    • Ink volume: Adjusts the amount of ink printed on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the faster the printout will dry.
    • Dry time: Provides extra drying time for slow-drying printouts. Drag the slider to the left for less drying time, or to the right for more drying time. The printer will hold onto the printout until the dry time has elapsed.
Step three: Check the ink levels NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox .
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab and then click Service this device .
  2. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low
99ac57c.gif If the steps above have not resolved the issue, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
  1. Load the input tray with unused plain white paper.
  2. Press and hold the Cancel (c00636162.gif ) button and then press the Start Copy Color (c00636190.gif ) button.
  3. Release both buttons. The self-test page prints.
Step five: Note which cartridges printed which areas of the self-test page You must identify which cartridge printed which part of the self-test page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different self-test page patterns. Your self-test page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Step six: Look for defects In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) should contain few or no missing lines. None of the colors should be missing and the colors of the blocks at the bottom of the page should match the labels below each block. Also, there should be no streaks of ink on the report. Missing lines or streaked bars If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly. Figure 4: The magenta pattern shows missing lines and the bar is streaked 7e505a5.gif
Jun 12, 2008 | HP Office Equipment & Supplies
It will not print. It passes the paper through without printing anything on it. The ink cartridges are new. It prints a test page. but it will not copy. The computer says its ready to print. The...
A test page prints with the proper ink/text showing up?Have you tried restarting the computer? Have you powered off the printer and turned it back on? You could try reinstalling the printer software and see if that helps.
Mar 21, 2011 | Dell 948 All-In-One InkJet Printer
My mx860 is printing fine for every ink cartridge except the big black one. it hardly prints the black ink at all - sometimes i just get a black page. this is recent - after a month of not using it. i...
Hold a piece of tissue under the ink jets and see if the tissue draws ink out of the cartridge. If not the cartridge is blocked or empty. If ink does come out there may be a faulty contact on the cartridge or printer. Try swap out the cartridge with a known working one and see if that works.
Jan 26, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Printing
Have you been using the printer lately? Is the ink dried up? Have you gone into the printer preferences to check your settings?
Aug 04, 2008 | Epson Stylus 880 InkJet Color Printer
PRINTER CARTRIDGE STALLED
Is there someting stuck in the printer like a pencil or a keychain, something small that would allow paper to pass but also trigger a sensor in the printer as the printer can detect that paper is being passed unevenly.
Question: does it just say that the ink cartridge is stalled or does the cartarige really stall?
Feb 20, 2008 | Computers & Internet
How do I reset the ink levels?
Well, theres the problem. Most printers can remember up to three cartridges. That includes color & black. The best way to put it is that each cartridge has a"funger print" that the printer can read, and estimated ink levels can be gaged. There is a way to "reset" the cartridges, but i do not have the document on me. Please email [email protected] and I'll send it today. I'm not saying it will work 100%, as the reset method is geared for the 56/57/58, but who knows right?
Jun 19, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
743 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
