Question about Yamaha Electrical Supplies
HOW MUCH HORSEPOWER DOES MY YAMAHA EC4000DV HAVE
Serial no. 469271 70 h.p. yamaha outboard motor what year is it?
It is not possible to retriev a year on yamaha with only the serial number.
On the serial number sticker, you'll find other data, like type, length, horsepower, weight etc...
In the link I give you'll find all the needed data and you will be able to obtain a mfg year...
Posts Tagged Yamaha Outboard Serial Numbers
Oct 06, 2017 | Yamaha Boating
50 horsepower yamaha replaced power trim motor it will not lift motor only puts it down
You might have 2 bleed the system 2 make sure their is no air in the system
Aug 28, 2017 | Yamaha Boating
Weight of 17 foot fibreglass boat and 115 horsepower Yamaha motor
the weight of the motor will be obtainable from the Yamaha web site in the specifications section the weight of the boat is any body guess as you didn't give a manufacturer name
most marine shops will get close as they are familiar with boat constructions and supply trailers to suit
Aug 01, 2017 | Yamaha Boating
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Fazer Brakes, Weight and Fuel Capacity
    • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
Jan 14, 2013 | 2003 Yamaha FZS 600 Fazer
What is the torque for 2001 yz 250
Hi, Amigoamigo 30.6 foot-pounds force (41.5 N·m) of torque at 7,500 rpm, for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha YZ250 Wikipedia the free encyclopedia
Highest horsepower yz250
Yamaha YZ250 Owner Service Manual
OEM parts for Yamaha
Yamaha yz250 2015 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 02, 2011 | 2003 Yamaha YZ 250
How many hp. could have yamaha v max 2004
The V-Max's horsepower numbers are 110.6 hp at 8200 rpm, cresting the 100-hp mark from 7100 rpm to redline at 9350.
http://www.motorcycle-usa.com/275/924/Motorcycle-Article/2004-Yamaha-V-Max.aspx
Oct 01, 2009 | 2004 Yamaha V-Max
1854-Yamaha V-Twin Motorcycle Engine
The horsepower of that mighty beast is exactly 100 horsepower (73.6 kW). Here's some of the other specs:
  • Engine Type - Air cooled, 4-stroke, V-twin engine, OHV, 4 valves
  • Displacement - 1,854 cc
  • Bore & stroke - 100 x 118 mm
  • Compression Ratio - 9.5:1
  • Max. power - 73.60 kW (100 HP) @ 4,250 rpm
  • Max. torque - 167.80 Nm (17.1 kg-m) @ 2,500 rpm
  • Jan 17, 2009 | 2006 Yamaha Roadliner
    Electrical Supplies Logo
    27 people viewed this question
    Top Yamaha Electrical Supplies Experts
    John Trevino
    jmt
    Level 1 Expert
    Robert Wooley
    Robert Wooley
    Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
