Question about JVC KD-LX1 CD Player
My problem is the ribbon wire connected to front panel is open
  • 218 Answers
Try They carry that sort of thing. Good luck.
Posted on Aug 29, 2007
0 characters
3 Points
My pioneer deh-p8450mp is opening and closing/switching on and off contiuously. help
Hey sparrow, sorry you didn't get an answer to this sooner, mine just started doing the same thing. After fidling and dismantling for an hour or so I think I have diagnosed it to being the ribbon cable which comes from the circuit board to the front most control panel is cracked (i.e. the cable that connects to the connectors on the removable face plate) When the panel attempts to open fully the ribbon cable is flexed enough to lose connections making the unit think the faceplate has been removed and so attempts to close...when it closes the connectors retouch causing it to think it needs to reopen....this is a nasty design flaw for a unit that cost me $1500 (admitedly 10 years ago but it was in a box in the cupboard for 8 of those years) !!!! Now any chance I can source this $2 part .....eek
Oct 03, 2009 | Pioneer DEH-P8400MP CD Player
I have a JVC KD SH55 and won't eject CD. Fix please. Recall?
there is a ribbon wire that connects the faceplate contacts behind the faceplate that always go bad on all radios with rotating faceplates. you can probably find this part on ebay or on or by jvc.
Sep 08, 2009 | JVC KD-SH55 CD Player
Dual XD7500 Faceplate Problem
the faceplate has a loose or broken contact on one of the wires on the ribbon wire located in back of where the faceplate mount. the ribbon wire is expensive and you must open the radio and install it. the wire is about 30 bucks plus shipping from the dual company or namsung. you can also find the ribbon wire for sale at or
Jul 16, 2009 | Dual XD-7500 CD Player
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
Jun 18, 2009 | Pioneer DEH-P9600MP CD Player
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Deh-p9800bt My screen is gone
I opened the radio and found that the wired ribbon that connect the front display plug to the inside main electronic board was cutted on the place that the ribbon bends when the face plate move in and out to take off the display or put a CD.(It sees like after years opening and closing ribbon makes an edge and break). I called Crutchfield and they brought this phone # for Pioneer replacement parts, Tel. 1-800-228-7221. I called and ordered the part (P/N:XNP7026, FACEPLATE RIBBON CABLE - $24.95) and I installed it, the decks is working perfect! If you have electronic working experience will be easy, if not, buy the part and bring it to an electronic shop. The front connector plug has to be reused. This cable is used on other models like : DEHP6800MP, DEHP7800MP, DEHP780MP, DEHP9800BT, and the DEH980BT. Hope that this help!
Jose Carrasquillo- Puerto Rico
Mar 19, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Front panel wont come down
i had the same problem. i took my radio in and they opened it up and the flexible pcb was snapped in half...
Jan 15, 2008 | Sony CDX-M800 CD Player
Inside display panel not working
the ribbon that connects the front pannel to the back has broke the ribbons are avalible from ebay
Sep 13, 2007 | Sony CDX-M8800 CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
JVC KD-LX1 CD Player Logo
63 people viewed this question
Top JVC Car Audio Receivers Experts
xxxxxx xxx
Are you a JVC Car Audio Receiver Expert? Answer questions, earn points and help others
