Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
DE73 A04 Error code
My machine is about 3-4 years old and his been running fine until recently when it occasionally shows a A04 error. Searching around I now know this translates to "Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute ". However I have no idea what this means or if there is anything I can do. Any ideas please!
  • TheHoff Aug 29, 2007
    Thanks, I will try this out next time I get the error and let you now what happens.
    Cheers.
  • 725 Answers
You may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Posted on Aug 29, 2007
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Error c2152 on Minolta c252 removed transfer belt whilst putting it back after cleaning the blade the machine showed C2152 and cant clear tried everything please help.
I did a Google search on your problem and most of the information indicated a motor needed to be replaced. On answer said to re-install the program as the on that was originally running the machine worked fine until it got the same error code.
Sorry I don't have an exact answer but the machine must be old as there were no answers that I could find that were recent.
Nov 03, 2014 | Office Equipment & Supplies
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
I have a Dell Inspirion 530, dual core quad processor. It's about 3 years old. I just recently started occasionally getting blue screen error. When I ran the memory test off of the bootable partion, I...
It sounds like you are having memory issues with your computer. The best thing you can do is just replace the memory the computer sounds just fine you just need new memory. If you go to this link http://www.newegg.com/Product/Product.aspx?Item=N82E16820134117&cm_re=DDR2-800-_-20-134-117-_-Product on newegg.com. Order these sticks of memory you would be fine. All you need to do is just open up the dell case. Remove the old memory sticks from the main motherboard. Then install the new sticks and you will be able to reboot your system and should run just fine.
Apr 25, 2011 | Dell Computers & Internet
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
339 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
