Question about Epson Office Equipment & Supplies
Instructions change ink cartridge epson fx-2175
  • 38 Answers
SOURCE: Epson Stylus DX7400 - Ink cartriges
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Posted on Dec 07, 2008
  • 326 Answers
SOURCE: changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
Posted on May 15, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
SOURCE: how to check epson fx-2175 Head
how to download epson fx 2175 printer cd
Posted on Feb 18, 2011
  • 15 Answers
SOURCE: have no instructions or manual
Here is a link to the full user manual for your printer:
http://www.safemanuals.com/314159.php?k=b54fb42b1fc58afe98b32de9496e34d6&ID=552726&q=EPSON%20STYLUS%20CX3600
Posted on Mar 16, 2011
Epson FX 2175 has any paper length detecting sensor
No, Epson FX 2175 does not have any paper length detecting sensor. But it is a low maintenance and high performance workhorse printer you can definitely buy this.
Sep 28, 2016 | Epson Office Equipment & Supplies
I have epson fx 2175 ,,but bold command is not working ,when i use bold command in DOS document,
First check that your printer is set to ESC/p. "ESC E" to select bold and "ESC F" to cancel the bold.
Sep 14, 2015 | Epson Office Equipment & Supplies
How to set line per pages at epson fx-2175
load some paper in the printer, then follow the instructions below:
http://support2.epson.net/manuals/english/sidm/fx_2175/ref_g/CP_3.HTM#changing
you will need about 4-6 sheets of paper, follow the instructions.
Mar 09, 2015 | Epson FX 2170 Matrix Printer
Epson FX 2175 Matrix Printer page skipping"
Its in your settings go to the control panel where the printer is shown as the default printer with the checkmark beside it and right click and click on properties and check there.
Jul 27, 2011 | Epson Office Equipment & Supplies
Any body tell me how to change the Settings in Printer EPSON FX-2175 [by pressing keys in printer]
download the user manual here in pdf file: http://files.support.epson.com/pdf/lq2170/lq2170u1.pdf
Jul 14, 2011 | Epson FX 2170 Matrix Printer
My epson fx-2175 not printing text
Check that you have ink left. If you have, try to reinstall software and restart the printer. Good Luck!
Jun 08, 2011 | Epson FX 2170 Matrix Printer
How to check epson fx-2175 Head
Oct 04, 2010 | Epson FX 2170 Matrix Printer
I want to reset my EPSON FX-2175 printer
load buten not worker and load buten ,paper eject not but load to load
Jun 18, 2010 | Epson FX 890 Matrix Printer
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
