Question about Garden
How to install a john deere LX255 belt tensioner spring
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
  • 302 Answers
SOURCE: john deere mower deck belt
try this. unhook the tensioning spring so you can get the belt on and the get some vise-grips on the spring and re-connect it. hope this helps
Posted on Oct 08, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
SOURCE: John Deere LX255 PTO stopped
My John Deer LX255 will not engage the blades unplugged yellow switch and cleaned spades. What should I do next?
Posted on Sep 03, 2010
  • 203 Answers
SOURCE: looking for free download of
http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsListServlet?equipID=12679&language=english&searchCriteria=lx255&exactModelSearchFlag=off&orderBy=pubType&tM=HO
Hope that helps.
Posted on Oct 05, 2010
Does a John Deere model LX279 only have one belt
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX255 LX266 LX277 LX277AWS LX279 LX288 LAWN GARDEN TRACTOR...
Apr 27, 2017 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Where can i find a free john deere lx255 owners manual?
Don't know for free, but I found it on amazon, so take a look if you want.. here: Amazon com john deere lx255 manual. I hope this was helpful. Have a nice day
Apr 22, 2012 | John Deere Garden
I have a John Deere L120. How do I install the tension spring? The service manual diagrams for the belt are not very clear in regards to the spring.
I hear that on the service manual and the springs. Take a look at these decks if you talking about a deck belt and find yours. Then look for the spring routing visually.
http://opebycrigby.tripod.com/decks/jddeck.html
If you need drive belt info look here:
http://opebycrigby.tripod.com/drive/jddrive.html
I would like to know if this was enough info for you so that you were able to re-connect the spring.
Thanks for choosing FixYa,
Kelly
Jul 01, 2011 | John Deere Garden
Trying to change the blade belt on my john deere gx75 lawn tractor and can't can someone help me through this?
Get in touch with your common sense. You have the deck out from under the mower and you have cleaned it. By chance is there a belt install guide on a sticker on the deck? This is a very common sticker. If you can get on fixya you can Google "John Deere deck belt install" with your model number. Failing all that, look at all the pulleys and the belt itself. The belt is flat on one side and v shaped on the other. Now look at all the pulleys, some have a groove and some are flat. The groove tells you the v of the belt goes in there and the flat tells you it is to take up slack or absorbs shock and the flat of the belt runs touches it. There is but one way it will go. One of the pulleys moves in an arc on a spring loaded swivel, that is your tensioner and will be the last one as you will move the tensioner to get it installed.
Aug 22, 2010 | John Deere Garden
Apr 21, 2010 | Garden
John deere mower deck belt
Oct 07, 2009 | Garden
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
